Hurst shifter part #'s ?? - Team Camaro Tech
Old Apr 22nd, 02, 06:29 AM
DRJDVM DRJDVM is offline
Default
I've been searching for a Hurst Comp shifter for my 69 camaro with a 4 speed Muncie.
Do any of you guys have the correct part numbers for that application ???
The numbers people list on ebay seem to be all over the place, but they claim the shifter came from a 1st gen camaro etc....
On the Hurst website, the part number is 3917438....... but thats for the aftermarket, flat handle etc..... Some of the ones listed on ebay claim to be OEM units etc.
I also know the shifter is different for 67-68 vs 69......
I'm just trying to avoid getting ripped off by buying a shifter that is represented as a "compatible for 69 camaro", but isnt.
Old Apr 22nd, 02, 07:14 AM
stingr69 stingr69 is offline
Default
Frequently the last 4 digits of the chevrolet part numbers are stamped into the linkage. They can be found in the factory assy manual. I have a loose factory shifter but they don't all have numbers on them. Verify the linkage numbers from the seller and remember the big block linkage/bracket parts are unique from small block parts. Email me if you need pix.
-Mark.
[This message has been edited by stingr69 (edited 04-22-2002).]
Old Apr 22nd, 02, 08:22 AM
NealM NealM is offline
Neal
Default
Are you sure about that Mark?
I know the lock-out linkage is different but not the shifter linkage.
How would it make a differance if the shifter mounts to the trany?
Old Apr 22nd, 02, 10:14 AM
Default
I am absolutely sure about the big block having a different mounting bracket and different linkage. It is in the factory assembly manual that way.
The engine/transmission is in a different location for big block vs small block but the shifter itself must not move relative to the console or it would not fit. This requires different rods and bracket unique to the big block. The part numbers are:
Small-block: reverse #3955771 1-2 #9791876 3-4 #9791885 lower lock
#3955773
Big-block: reverse #3955779 1-2 #3955775 3-4 #3955777 lower lock
#3955776
The BB vs SB mounting bracket is different but I don't have the numbers handy. They are very different in apearance. Shifter stick/assy is the same either way.
Strange but true and realy does make sense when you consider how the big block is offset to one side. Another way they are different is the crossmebers. If the tranny was actualy in the same place, the crossmember would be the same, but it is not so the crossmember is different.
-Mark.
Old Apr 22nd, 02, 11:13 AM
Neal
Default
I'll have to check that out. I just don't remember see it.
Old Apr 22nd, 02, 11:29 AM
Default
I'm looking for the whole shifter, not just the linkage. Most of the shifters I've seen on ebay, dont have the linkage included but some do.
Isnt there a part number on the shifter ??? (not the handle)
Old Apr 22nd, 02, 02:50 PM
Default
The levers are different for the Saginaw too! Are we having fun yet?
The spare factory shifter I have only has a "9 7A3" which I believe is a date code on the outside face along with the patent number and the "Hurst Competition/Plus" stamping. It has "3138" on the front of the shifter in tiny numerals near the bottom cover slot. That is probably the number you need to look for.
Hope this helps.
-Mark.
Old Apr 22nd, 02, 05:46 PM
Default
Mark- Wanna sell it ????
merch120 merch120 is offline
Default
Mark is correct..the number is 3138...that number is used in both the Camaro and Firebird. They both used the same shifter body.
Old Apr 22nd, 02, 06:19 PM
Neal
Default
Hey Mark,
I found the info in the manual. Interesting
Old Apr 23rd, 02, 01:07 AM
Default
DRJDVM,
sorry I can't sell parts on this forum. It is not for sale anyway. I predict the correct ones will become as rare as hens teeth soon. Shifter itself can go for around $150 in average condition but the whole correct setup can go for $300-450 depending on condition. The repro linkage is a joke so you can forgetaboudit. Alec Manoccio has them for sale from time to time. If you need contact info email me offline.
-Mark.
