396/454 plugs ? - Team Camaro Tech
Old May 28th, 03, 01:12 PM
Dan Smart Dan Smart is offline
Question
What do you recommend for a 396+60 w/781 heads?
I've tried Accell 276 plugs without much success
Thanks in advance, Dan
<a href="http://hobbystage.net/camaro/narley68" target="_blank">http://hobbystage.net/camaro/narley68</a>
Old May 29th, 03, 06:02 AM
Codi's Avatar
Codi Codi is offline
Jim
Post
I usually start with whatever plugs are recommended for the engine, year, vehicle, etc. I try them then read them to see what changes (heat range, extended tip, etc.) I need to make and adjust accordingly. I was never a fan of Accel plugs. I typically use Autolite in my engines as they seem to last longer.
Daddy's Hot Rod.
http://www.camaros.net/showroom/show...e=365&way=desc
Old May 29th, 03, 04:00 PM
67camss/rs 67camss/rs is offline
Angry
Just from memory,Ithink Ihave Autolite 26 or 27 in the 396. Will check this weekend.
Gene
Old May 31st, 03, 12:15 PM
RAT454 RAT454 is offline
Post
I used Champion RV12YC with my 781 heads.
Old Jun 3rd, 03, 12:14 PM
Post
Thanks for the recommendations guys. I put in a set of the AC R45ts plugs & so far so good. Next will be Autolite 27's. It's nice to have a smooth running engine.
Thanks again, Dan
