Engine General Engine Discussion
Old Nov 4th, 99, 09:51 PM
Jamers Jamers is offline
Default
I have an '89 RS Camaro with a 2.8 V6 and I recently had to change my fuel pump. About a week after I changed my fuel pump I have noticed that my car is taking longer to start up (It used to start up right away-now it cranks over for several seconds before it fires up). Once it is running it is fine and the performance is fine, therefore I am not sure if I should suspect the fuel pump. Any one have any ideas?
Old Nov 5th, 99, 09:09 AM
elcamino72 elcamino72 is online now
Bryan Shook
Default
Did you check you fuel pressure regulator?
Old Apr 17th, 01, 11:33 AM
GregHipkin GregHipkin is offline
Post
<BLOCKQUOTE>quote:</font><HR>Originally posted by Jamers:
I have an '89 RS Camaro with a 2.8 V6 and I recently had to change my fuel pump. About a week after I changed my fuel pump I have noticed that my car is taking longer to start up (It used to start up right away-now it cranks over for several seconds before it fires up). Once it is running it is fine and the performance is fine, therefore I am not sure if I should suspect the fuel pump. Any one have any ideas?<HR></BLOCKQUOTE>
Old Apr 17th, 01, 11:35 AM
Post
I have a similar problem. Were you able to solve your problem? If so please share the results.
Thanks.
Old Apr 17th, 01, 12:46 PM
Alfonso Perez Alfonso Perez is offline
Tech Team
Wink
Dirty injectors. You need to have them cleaned.
