th350 - Team Camaro Tech
Old Nov 22nd, 99, 02:49 PM
67resto in progress 67resto in progress is offline
Default
CAN SOMEBODY TELL ME IF THERE ARE ANY DIFFERENES IN TH350 TRANNYS>?AND IF THERE ARE WHAT TRANNY SHOULD I LOOK FOR FOR MY 67 RS.
THANKS AGAIN.
Old Nov 23rd, 99, 06:14 AM
Shawn Shawn is offline
Default
See the Performance section on TH700r4 vs TH400 etc. For Rock solid durability- Get a TH400, a TH350 may be only slightly cheaper, but not nearly as strong as a TH400. You can usually nab a good used 400 for under $500. TH700R4, good for the over drive, but really need to sink money into one if you are putting a stout motor in front of it.
Shawn "My Camaro is a money pit" Peterson
Old Nov 23rd, 99, 12:38 PM
Default
thanx for your help i will do that
Old Nov 26th, 99, 03:36 PM
Garry Gagnier Garry Gagnier is offline
Tech Team
Default
Yes 67 resto there are three different lengths 6 " 9" and 11" .You want a 6" tailstock also make sure the case is a chevy boltpattern, this will bolt in where your 2 speed was. You will need the kickdown cable dipstick and tube, also vacuum line.You will also need a 3 detent shifter if you want the original look. Garry.
