Engine General Engine Discussion
Old Oct 3rd, 99, 06:11 PM
68bigrat 68bigrat is offline
Default
I have a '68 with original 10 bolt and I am in the process of acquiring a 12 bolt posi from a 69 (Camaro) my question is : Will I need to adapt shock mounts or change drive shaft length or anything else or is it a straight swap? Thanks
Old Oct 4th, 99, 01:01 PM
drptop70ss drptop70ss is offline
Default
It will be a straight swap, no problems..
66/70 chevelle ss396's
69/71 camaros
Old Oct 4th, 99, 01:14 PM
elcamino72 elcamino72 is online now
Bryan Shook
Default
Droptop is correct, its a straight swap.
Bryan Shook
Burgettstown, Pa
Old Oct 5th, 99, 02:07 PM
Kevin Kevin is offline
Default
Actually the driveshaft for a 10 bolt is slightly longer than a 12-bolt one. I just swapped out my 12-bolt for a 10 bolt (read: 3.73's too low for California freeways) and had to shorten the shaft by 1/2".
Old Oct 6th, 99, 03:05 AM
68SS396 68SS396 is offline
Default
Kevin, you said the 10 bolt driveshaft was longer. If thats true, then if you changed out the 12 bolt for a 10 bolt wouldn't you need to lengthen the driveshaft, not shorten it?
Old Oct 7th, 99, 07:34 AM
Default
My bad, sorry to mislead. I meant that the length of the differential where the driveshaft connects is longer which necessitates a shorter driveshaft.
Old Oct 7th, 99, 02:34 PM
Default
I still say its a straight swap, done it before on both chevelles and camaros..
69/71 camaros
Old Dec 29th, 99, 07:41 PM
Trick1 Trick1 is offline
Post
check to see if they both had the same number of springs ie. monoleaf or multileaf you might have to change the rubbers in the perch.
Old Dec 30th, 99, 10:20 AM
camaroguy camaroguy is offline
Post
I adapted a 66 chevelle 12 bolt for my 67 and
had to shorten the shaft by a 1/2 inch.
The 69 12 bolt in my experience bolts right up except if you have mono leafs. You will have to change to multi leafs or change the perches. Been there and done it several times.
Just my 2 pennies.
