Vortec Heads with Domed Pistons - Team Camaro Tech
Thread Tools Display Modes
Old Dec 17th, 99, 11:54 AM
69-er 69-er is offline
Larry
Default
I've heard that domed pistons will not work with Vortec heads. Any comments?
Larry
Old Dec 17th, 99, 12:10 PM
gheatly gheatly is offline
Gene
Default
Why do you want to use domed pistons? Based on many years of reading Hot Rod and discussions with engine builders, flat tops are better, especially with more recent cylinder head designs such as the Vortecs. These heads attempt to induce swirl or tumble to the mixture to provide faster combustion. Piston domes impede flame travel across the cylinder because the flame has to go over and around the dome.
Old Dec 17th, 99, 02:15 PM
1st & 2nd GENGuy 1st & 2nd GENGuy is offline
Default
I agree with the prior response. Plus the vortecs are small cc (I think 64) and that small of a camber with domed pistons will give a high compression ratio (which does not work well with todays gas).
Old Dec 22nd, 99, 07:23 AM
Larry
Post
The reason I need high compression is that I'll be using the heads on a circle track car motor. The cam requires high compression on the order of 11:1 to 12:1. I'm impressed with the flow on these heads and would really like to try them.
Larry
Old Dec 22nd, 99, 08:17 AM
tom3 tom3 is offline
Post
These heads are not straight across between the valves at the quench area, I suspect this would cause some interference with the piston dome. This 'kidney' shaped area is supposed to be part of the improved design that makes the heads work so well.
Old Dec 29th, 99, 06:45 PM
Trick1 Trick1 is offline
Post
I would go with forged flat top pistons and have the heads shaved to bring up the cylinder compression.
Old Jul 10th, 01, 07:41 PM
subdriver subdriver is offline
Tech Team
Question
Domed pistons will not work unless made for the vortec chamber. Shaving the heads may help your compression some, but the real question is what exactly are your intentions. On a strong street motor they would be great but on a high RPM race motor I think you could do better. They have 1.94/1.50 valves which are small for high revs. The stock springs and press-in studs may not work well either. For a little more you could get world sportsman II heads, or good aluminum heads and not have to use a different intake(less options to choose from with vortecs). I have a set on my 81 suburban and I'm pleased with them but wouldn't recommend them for over 6500 RPM. Under this RPM I wouldn't think you would need much more than 10:1 compression. Flat top pistons with the 64cc chambers should run about 9.5:1 or a little more without cutting the heads.
Old Jul 10th, 01, 10:36 PM
travis travis is offline
Post
I would also use a forged flat top piston, 0 decked, and mill the heads accordingly. With stock 64cc chambers and 0 decked flat tops, you are already at 10.25-10.5 to 1. You'll definately want to change the springs as the stockers are pretty weak, and pay close attention to the retainer to guide clearance.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
Old Feb 14th, 02, 06:48 PM
street-racer-n-okc street-racer-n-okc is offline
Tech Team
Post
I have vortech's on my 350 with a set of .125 domes and haven't had any problems I'm also running fel-pro 1094's which bump it up to about 11.4:1 i still run 91 but have to keep the timing back a little.
[This message has been edited by street-racer-n-okc (edited 02-26-2002).]
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Vortec Heads with Domed Pistons
Location
Location
First Name
Human Verification
