| Team Camaro Tech Current Topic: Whats the difference & pros/cons of " I " and " H " beam rods? | ||
| Engine General Engine Discussion. |
Im in the process of building a 406 small block and need all the help that I can get. Someone posted here "help me to build a killer 406" and I have read this over and over again. I was curious though as to the differnece, and the pros/cons of "I" and "H" beam rods. Thanks in advance.
And just for kicks, do you think that a Scat or a Eagle engine kit (including crank & rods, I will be using Ross pistons also , I understand there extremely good and reliability) would be possible of supporting 500-600 h.p.? Thanks guys |
| Sponsored Links | ||
Advertisement | ||
In my limited experience, H-beam rods are stronger, but overkill for most applications. However, they can afford you some clearance between the cam and cap bolts if your doing a stroker motor.
-dnult
Dave ======================== 68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI |
All the top manufacturers use I beam rods, or A-beam.
For the money, Crower Sportsman Cap screw rods are the lightest and highest rated, as well they are made right here in the USA!
Gold 67' Camaro<br />Small Block BSE power in the works. |
H beam rods are (In theory) stronger and more stable at higher RPMs with lower rod ratios and have been considered overkill in most streetable applications. Personally I dont know if I can swallow the overkill part, but whatever, I use H beam rods in street engines.
H beam rods are a good consideration where ENDURANCE is and WEIGHT is not an issue. Although, the I beam rods are normally a little lighter than their H counterparts. So for a streeter, I think the aspect of weight to cost is the biggest PRO/CON issue. This and the total bob weight can be a concern for some engine combinations as well. The Eagle kits are good for 500-600hp comfortably. |
Eagle H-beams are so beefy on the rod cap end that you'll have to grind quite a bit on the pan rails and take a chance of hitting water. Check out Scat's new 4340 I-beam Pro series rod. They use a shorter rod cap screw and according to my machinist, they'll clear the cam on the top and pan rails on the bottom with no grinding at all in most cases. I have a set for my 406 and they look pretty impressive. Machining is not quite as pretty as Eagles, but he's built engines hitting 600 on the dyno without problems. HTH.
Check out this link! This site has a lot of info!!!
http://www.grapeaperacing.com/GrapeA...h/rodtypes.cfm |
Hitting H20 !?!!
Somewhere I read that there IS a street application aluminum rod out there that lasts close to the stock steel rods but I don't remember where I read it or who makes them.
I am wondering if these are made out of a refractory grade ceramic fiber filled aluminum matrix material for extra fatigue property increases b/c I do know they are using this kind of material now for diesel engine pistons, or at least I think I do??? And, somebody, I think Crower, is making a magnetic Titanium rod, again if not mistaken, that will pass a Tech. magnet check that is really light although can work-harden and eventually become brittle if I remember my metallurgy here?? Plus, these fall into the "unobtainium material" money range if you get my drift!!! You know I think all Briggs & Stratton lawn mower motors have aluminum rods in them AND the little abused suckers very seldom throw one!!! pdq67 |
"refractory grade ceramic fiber filled aluminum matrix material" !?!?!! Holy crap Scotty, the antimatter containment field is collapsing . . .
Seriously, there is some debate over which is better H or I beam. Both have been used in very high HP race motors with success. I don't think you would have a problem with the Eagle SIR rods in a 500-600 HP motor that sees an ocassional 1/4 mile blast. They are rated at 500 but can handle a little more than that I'm sure.
E85 racer and E85 carb builder www.horsepowerinnovations.com 68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle |
| Sponsored Links | |
Advertisement | |
