Shimming a starter - Team Camaro Tech
Old Jun 12th, 00, 05:40 PM
CamFrk68 CamFrk68 is offline
Ken
Cool
I had the fun task of matching a starter to to '70 block to a '65 chevelle Muncie 4sp. I found a starter that fits the flywheel, but I am unsure if I have it shimmed correctly. Is there a way to gauge it and if so what is the process. I don't want to ruin my flywheel
Old Jun 12th, 00, 06:18 PM
camcojb camcojb is offline
Jody
Post
Most of the starters I've had want about .035 clearance at the bottom of the tooth when engaged to the flywheel; carefully pry the starter gear into the flexplate with a screwdriver and check it. If it's too tight they offer shims to move the starter away from the block, increasing the space between the gear and flexplate. If it's too loose (over .060 or so) you can shim just the outer starter bolt (towards the outside of the engine) to decrease the distance. I rarely get .035; I've had .050-.060 with no problems.
Old Jun 13th, 00, 03:34 AM
71 Camairo 71 Camairo is offline
Cool
Another good way is to take a 1/8" drill bit as a gauge. With the starter snugged to the block as a starting point. Take and stick the drill bit between the starter shaft(perpindicular to) and flywheel. Shim your starter accordingly. The idea is to get little resistance on the drill bit. Has never failed me yet. Hope this helps
71 Camairo
Old Jun 13th, 00, 10:43 AM
DOUG G DOUG G is offline
RedЯuM
Post
a guy at a old mom and pop auto parts store told me to use a large paperclip (unwound), and that it's .035(checked with a mic. and it was .0347....go figure.
My68Camaro
Doug G.
68 Camaro
406 ci.
