oily plugs - Team Camaro Tech
Old Sep 11th, 04, 10:00 AM
rolling-robert's Avatar
rolling-robert rolling-robert is offline
robert
Post
hi,
on my new 355ci (see sig) i pulled the sparkplugs and noticed on every plug oil on the threads, i cant see any oil leaking from the valve covers.
I dont think it leaks oil into the cylinders, i mean, not on all 8 cylinders.
the top of the plugs were a little black, but i think its because of the new carb is idling a little rich, the tips were dry but black.
what do you guys think it can be?
take care
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
Old Sep 11th, 04, 02:20 PM
jethro jethro is offline
Post
Well, on my Accel 576's, there SHOULD be oil on say, the first three threads... also, a little black is NOT an issue in my opinion, only because I personally believe it is better to run a little rich, gas prices not withstanding. If you are thinking it is oil, then do a compression test, make sure carb is fully opened, just wedge a screwdriver under the throttle linkage with the return spring off, use a bump starter, count the same number of compression cycles on each cylinder, say five. Compare reading, yours should prolly be around 160 to 170 for each cylinder, with no more than about %10 difference from the average for any one cylinder. Do you ever have a little puff of blue smoke come out when you first start the engine after it has sat awhile?
Oh, I forgot, go to this site:
http://www.eric-gorr.com/techarticles/sparkplugs.html
67 Camaro | 350 | 650 Speed Demon | Dual plane GMPP intake | MSD ignition | Secret Cam (I don't know what it IS!) | 2.02/1.60 Camel Humps ported | Thorley Tri-Y's | 8.5 10 bolt 3.73 | M22
Old Sep 11th, 04, 07:47 PM
robert
Post
no, no blue smoke, it used to smoke blue during idling, but after resetting the idlemixture, its gone
Z28 1984
