REAR MAIN SEAL LEAK - Team Camaro Tech
Old Oct 4th, 00, 08:15 AM
ssdanny69 ssdanny69 is offline
Post
Is this normal for it to leak (very small) after installin a new motor? If so, will it decipate after the internal parts set?
Old Oct 4th, 00, 12:33 PM
mccorry's Avatar
mccorry mccorry is offline
Steve
Question
I wouldn't think that the rear main seal should leak at all. Are you sure it is the seal and not the back manifold valley gasket?
Old Oct 5th, 00, 02:51 AM
Mark W. Winning Mark W. Winning is offline
Post
Only time I had one leak so soon after a rebuild was when I put the seal in with the lip facing the wrong direction.
Mark
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
Old Oct 5th, 00, 04:27 AM
Post
I'm fairly certain that it's the rear main seal. I just had the tranny pulled and rebuilt (4spd Muncie) could this have caused it to leak? Thanks for your input!
Old Oct 5th, 00, 11:47 AM
mbrekke's Avatar
mbrekke mbrekke is offline
Mark
Post
Did you check where the oil pan bolts up to the block in the rear?
Mark
Old Oct 5th, 00, 12:00 PM
CarlC CarlC is offline
Post
What about the oil pressure switch or pressure line?
Click here to see see my car and hear 5-speeds. http://www.geocities.com/casanoc
Old Oct 5th, 00, 01:06 PM
mccorry's Avatar
Steve
Post
hmmmm.....Fresh tranny (std.) and an apparent rear main seal leak. Could it be the front seal on the transmission?
Steve
Old Oct 5th, 00, 01:53 PM
pdq67 pdq67 is offline
Banned
Unhappy
400's are known to weep due to the seal backup area being slightly oversize I think after the crank is turned (or something like that). I know my 406 has always weeped slightly and I sealed the rear main seal backup as well as rotated the ends of the seal about a 1/4" plus dabbed on a smidgin of RTV on each end and even put a little on the main cap/block itself. Good luck. pdq676
