Lt1 to carb conversion, need help - Team Camaro Tech
Thread Tools Display Modes
Old Jan 30th, 02, 07:27 PM
j2cool2000 j2cool2000 is offline
Post
hello just wanted to say hi, new to the board, lots of great info in here.i have a question is someone can help me out i have a 1995-1996 Lt1 350 im pretty sure i bought from a guy as a long block, less intake and distributer etc.i know it is set up for fuel injected but i would like to make it into a carburater set up is this possible and has anyone else did this with good outcome?also any good machine shop in the dallas area thanks
Old Jan 30th, 02, 08:02 PM
novaderrik novaderrik is offline
Post
welcome aboard
you can get an intake from GM to put a carb on it(expensive), and any old HEI distributor will fit. you can either just leave the stock optispark unit on the front of the engine, or make a blockoff plate for it. you will need an electric fuel pump, and the LT1 accessory mounting brackets.
other than that stuff,and the usual million little things that pop up, it is a bolt in.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels
see pics here http://community.webshots.com/user/novaderrik
Old Jan 31st, 02, 04:15 AM
Post
hey thanks for the quick reply sounds like a lot of trouble and money to switch to carb is there an after market intake i can get for it say eldelbrock etc.or would you say to trade this block for an older one so it will be easier? thanks
Old Jan 31st, 02, 10:01 AM
Post
when i say the intake is expensive, i mean that it is about $300 or so. that seems like a lot to me, but if you intend on keeping this for a while, it might not be too bad of an investment. but it would be cheaper and easier to put an older style engine in it.
Old Jan 31st, 02, 05:24 PM
ZZ-28 ZZ-28 is offline
Post
A guy at work was asking this question today. He bought a "test" engine that codes out to a '95 LT1. He has just the long block. Supposedly these engines were used for a lube oil test and 50-100 of them are now being sold. After looking at the cost to convert he is now having second thoughts.
Old Jan 31st, 02, 05:33 PM
ScottE ScottE is offline
Thumbs down
Assuming i read the post correct and if your engine is an LT1 any HEI distributor will not fit. The LT1 uses an optispark distributor.
Old Jan 31st, 02, 08:25 PM
Post
if you put a carb intake on it, you can run an HEI distributor- you just take out the oil pump drive from the lifter valley- it looks like a dummy distributor shaft that had the top chopped off. once you get the intake on it and the HEI in it, it will look like any other small block, but have no water crossover on the intake, because that is on the water pump housing.
GM used to sell the LT4 as a crate motor with a carb intake and ZZ4 HEI distributor included. they put one of those engines in a Chevelle in Chevy High Performance a few years back.
Old Feb 1st, 02, 10:31 AM
Markus Markus is offline
Post
Yes, look at the tests in the CHP. I think there´s a lot of information for the carburated version.
The engine itself has a lot of high quality parts so I won´t do any exchange.
For my part I would prefer to look for the EFI unit.
Markus
69`Camaro, 92`LT 1 / 4L60
Old Feb 1st, 02, 12:09 PM
Post
hey novaderrick thanks for the posr reply sounds like a task to change things over still debating if i should just sell this motor and go with one older. hey how about the radiator will i have to use one from a =n lt1 since the coolent is reverse flow.alos do any of you guys know where i can get so used parts for the lt1 like dampener,external brakets for altenantor,etc.? thanks guys
Old Feb 2nd, 02, 06:20 PM
Igot2'72's Igot2'72's is offline
Tech Team
Post
there are a lot of places that salvage LT1, LT4 and LS1 motors. Do a quick search on Google or one of those search engines and you'll find a lot of resources. Ebay usually has a lot of LT1 parts for auction, too.
Oh and as a warning, those outer brackets you mentioned are expensive. Look in Chevy High Performance or Car Craft. There's usually a few different ads in there for custom LT1 bracket kits.
[This message has been edited by Igot2'72's (edited 02-02-2002).]
  #11
Old Feb 2nd, 02, 07:15 PM
Post
thanks igots2722ill look into those web sites
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Lt1 to carb conversion, need help
Location
Location
First Name
Human Verification
