| Team Camaro Tech Current Topic: How to clean Washer Fluid & Coolant Reservoirs | ||
| Engine General Engine Discussion. |
My Washer Fluid & Coolant Bottles are dingy yellow. Does anyone have a cure to make them white again?
1982 Camaro, 305, 4bbl Q-Jet |
| Sponsored Links | ||
Advertisement | ||
I just cleaned mine last night with some Castrol "Purple Power" and a scrub brush. Cleaned all the grime off mine.
yes he is right, you can use a form of grease cutting formula on both the inside and out. a bottle brush is great on the inside and the out side use a towel, like the ones you dry off with when you get out of the shower, it has a ruff surface but not too ruff to scratch it. the other thing is too put it in a bucket of bleach and let it bleach itself.
CLR might be a good choice to remove cooling system rust stains from inside the overflow bottle.
-dnult
Dave ======================== 68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI |
| Sponsored Links | |
Advertisement | |
