voltage reg + horn relay mounting location - Team Camaro Tech
Old Nov 2nd, 04, 04:10 PM
MR454SS MR454SS is offline
Post
Would someone post a clear picture of where these 2 parts bolt to the core support,also the small post terminal block near the battery that the small wire off the positive battery cable attatches.also where do the horns mount on a 69.on my new core support the holes on the drivers side don't seam to line up? Thanks!
Old Nov 2nd, 04, 05:03 PM
DenRS's Avatar
DenRS DenRS is offline
Post
I don't have any pictures, but the horn relay mounts on the drivers side of the radiator. The voltage reg mounts below it. If you have a 23 inch radiator, I'm not sure where you would mount the relay. The horns on a 69 should mount behind he grill in front of the radiator on the hood latch assembly. There should be bolt holes on both sides of the assembly to mount both horns.
1969 Camaro 350, Trickflow heads, ST-10 4spd, Hotchkis suspension, Baer SS brake kit, moser 12bolt
