| Team Camaro Tech Current Topic: Starter Wiring | ||
| Electrical & Wiring Troubleshooting electrical. |
Need help here folks. I am replacing the engine wiring harness in my 68 w/a 350ci using a Factory Fit harness. Question being is that at the end of the harness I have 2 wires. One purple that goes to the battery side of the starter solenoid. The other is tennis ball yellow and might?? go to the other post on the starter solenoid. Have looked at the wiring harness in the assembly manual but no help as it does not seem to clear to me where this wire goes. The car starts fine but want to connect this other lead in the right place w/o frying my solenoid. Any help would be appreciated.
------------------ 68 Camaro Convertible, 350SB,5spd,9" |
| Sponsored Links | ||
Advertisement | ||
Check out my reply to need help rewireing my coil on a 74, I think you will find your answer is the same.
Thanks guy. Wasn't sure but I figured someone out there would know. In the midst of replacing both the engine and front light harness now. I wish the previous owner hadn't been so liberal in his use of electrical tape and solder.
| Sponsored Links | |
Advertisement | |
