Parking Lights on a 67... - Team Camaro Tech
Old Dec 20th, 02, 01:28 PM
Johnny in AZ Johnny in AZ is offline
John
Default
Should the parking lights (front turn signals) come when the headlights are turned on ??? I pull my switch out a bit and the parking lights come (I mean the front turn signal lights)...But when I fully pull out the switch the signal lights go out....
Is this the way it is supposed to be ????
Thanks for the help ...
John
Old Dec 20th, 02, 02:23 PM
jackr jackr is offline
Default
Supposed to be like that. Parking lights OR headlights on the 67's.
Old Dec 20th, 02, 03:41 PM
1 2RUN 1 2RUN is offline
Default
Yep. One or the other not both on a '67.
'69 RS Camaro
355 5-speed 4.11
Old Dec 20th, 02, 04:25 PM
John
Default
Thanks for the Quick responce.....
I appreciate the info...
John
Old Dec 20th, 02, 05:37 PM
CFunK CFunK is offline
Call me Funk
Default
John,
If you want the parking lights on while the headlights are on do a search. There have been a couple of threads on a mod that allows both to be on at the same time.
-Funk
My '67 RS
Old Dec 21st, 02, 05:02 AM
Default
If you want them on with the headlights all you have to do is jumper them to the rear parking lights at the headlight switch. This can be done with two Scotchlocks and a short jumper wire so you don't have to butcher the harness.
'69 RS Camaro
355 5-speed 4.11
[This message has been edited by 1 2RUN (edited 12-21-2002).]
Old Dec 22nd, 02, 07:21 PM
bonecrusher67conv bonecrusher67conv is offline
Default
No need to jumper. Just take the rear wire out of the clip on the headlight switch and move it to the only open port in the front of the headlight clip.
