67 RS doors wire harness - Team Camaro Tech
Old Jun 6th, 02, 08:35 AM
mohawk mohawk is offline
Tech Team
Default
I recently purchased the headlight doors harness p/n C2480-1E from NPD. The harness I received has only two wires, a brown and a blue, with diodes, and the harness is 2' 7" long. My problem is this harness is not long enough to reach all four switches. I called NPD in FL and MI (where the part was shipped from) and neither departments could help.
Does anyone know where this harness go's too?
What harness do I need to connect all four switches together?
Thanks guys.
Old Jun 6th, 02, 09:52 AM
Geezer Geezer is offline
Default
I think that is the under dash to firewall harness, I'm at work so I cant look to see where it plugs in to under the dash.
Geezer
Old Jun 7th, 02, 01:40 AM
AAW AAW is offline
Default
The harness they sent you is the RS diode harness that is located under the dash. The two position connector plugs into the mating two position connector which comes thru the firewall from your RS front light wiring. The other end of the brown will plugs into the 'ACCY' location of the ignition switch (same location as existing brown, use pigtail). The blue wire will plug into the headlight switch (same location as existing light blue, use pigtail). The purpose of this harness is to allow the RS relay panel to know when the key is on (via brown), and when headlights are on (via blue). The diode is on the brown wire circuit, this prevents feed-back to the ignition switch. Hope this helps!
-Factory-Fit Wiring
Old Jun 7th, 02, 06:31 AM
Tech Team
Default
Thanks guys!
So what wire harness do I need to connect all four door switches to the relays and where ever else it connects to?
