Electrical & Wiring Troubleshooting electrical
Old May 10th, 00, 06:45 PM
stevo camaro stevo camaro is offline
Gold Member
Default
Baby68rs question about "blinkers" reminded me of a burning question I've had about mine. Is it normal for front parking/turn signal lamps to go out when headlights are turned on. My parking lights come on normally, but when I pull light switch all the way out for headlights, they go out. My turn signals work either way. Maybe this is normal for RS, I don't know. Anybody?
Steve
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
http://www.geocities.com/stevocamaro
Old May 11th, 00, 05:26 AM
CJ CJ is offline
Cris
Default
ON THE HARNESS FOR YOUR HEADLIGHTS THERE IS A SEPARATE GROUND WIRE. MAKE SURE ITS GROUNDED PROPERLY. THE FRONT MARKER LIGHT SHOULD STAY IN WHEN THE HEADLIGHT ARE TURNED ON.
Old May 12th, 00, 05:34 AM
Rob.Canada Rob.Canada is offline
Default
You have an older Headlight switch, probaly a switch from a 64 /65 chev.
As they are called PARK lights they are to be used only for parking, hence they turn off when the head lights are ON.
Old May 12th, 00, 05:46 AM
Chris Edwards Chris Edwards is offline
Default
CJ , your thinking of a standard Coupe,
on a R/S
YES IT IS NORMAL.
the parking lights go out as soon as the main lights are turned on , they come back on when the main headlights are turned off (if you only pushed the knob in 1 notch to have the P lights on again, )
and also remember that R/S cars will open the light doors with the key off, but require the key in the "on" position to close the doors.
Chris's 67 RS can be seen at http://www.geocities.com/macphreak4evr/index.html
JOIN THE CAMARO NET WEBRING! www.geocities.com/macphreak4evr/webring/webringjoin.htm !!!
[This message has been edited by Chris Edwards (edited 05-12-2000).]
Old May 12th, 00, 06:29 AM
CJ CJ is offline
Cris
Default
Hey Chris- on my 68 RS the park lamps stay on even when the headlights are on.
Old May 12th, 00, 07:29 AM
sixtsevnssrs sixtsevnssrs is offline
Tim
Default
Different switch for 68 than 67 RS. My 67 the Parking lights are on only when I am turning or if the swith is pulled to the first notch.
Tim
67 ss/rs, MODIFIED
Tim's Homepage
AOL-IM = sixtsevnss
Old May 12th, 00, 02:17 PM
Gold Member
Default
Sounds like 67 & 68's are a bit different. Also sounds like mine are working normally. Thanks guy's.
Steve
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
73 3/4 ton 454/400
Old May 15th, 00, 03:46 AM
Default
is that actually in the headlight switch itself, and if so are they similar in shape, just not circutry? , man that would be somthing to look for, to make sure they send you the correct switch. (if you needed to order one)
Learn somthing new every day.
Old May 15th, 00, 11:48 AM
Lonnie67 Lonnie67 is offline
Default
On both of my 67's with standard grill, the park lamps go out when the headlights are on. I think it is in the switch itself.
67 Camaro 410sb 11.63 @117.6
67 Camaro 388 ET-???
website
