Trunk mounted battery cable size. - Team Camaro Tech
Thread Tools Display Modes
Old Sep 11th, 04, 08:39 AM
pdq67 pdq67 is offline
Banned
Question
Can I get by with hooking a couple of long stock battery cables together for both positive and negative cables so that their combined length reach my battery in the trunk?
I'm planning on running from my starter's, big solenoid terminal rearward to the battery's positive terminal and from a bellhousing bolt reaward to the battery's ground terminal and then use needed heavy wire to run with them to wherever the other small wire goes?? (If I remember this right??)
The wife's old Astro Van Positive cable musta been almost 6' long so I figure two of them end to end should reach where I want to go??!!
Or please suggest needed welding cable or bulk battery cable size.
Thanks in advance..
pdq67
Old Sep 11th, 04, 08:59 AM
novaderrik novaderrik is offline
Post
get the biggest wire you can find- 0/0 to be safe. sure, it's heavy, but this is one case where bigger is better.
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
Old Sep 11th, 04, 11:27 AM
JohnZ JohnZ is offline
Team Member
John
Post
I've always used 1/0 welding cable for rear-mounted battery applications - always worked great.
[img]graemlins/beers.gif[/img]
JohnZ
CRG
'69 Z/28 Fathom Green
Old Sep 12th, 04, 09:24 AM
Banned
Post
Thanks everybody..
Do "Optima" bateries need to be externally vented by running a small hose from the box through the trunk floor or however?
I'm leaving my car's insides stock now back there at the rear seat "wall" area so am worried about any possible Hydrogen gas buildup sorta thing in my trunk since it is enclosed and not open like under the hood..
pdq67
Old Sep 12th, 04, 04:18 PM
SOA-Nova SOA-Nova is offline
Jim
Post
Originally posted by pdq67:
Thanks everybody..
pdq67
I also ran 1/0 wire on my car and for customer's and never a problem as long as I did both positive AND negative to the block. I also add a 300A ANL fuse right off of the battery to protect the cable should it ever become shorted or pinched and also solder on the terminal ends.
Optima battery venting in my view, I would do it. Even though they are not meant to gas the do have pop off valves on them and while I have never seen one pop them off I would wonder if corrosive and/or explosive fumes would be expelled in that situation. I would lean to the safe side and add a vent. You never know and it's cost to add it is fairly cheap.
Jim
1974 Spirit Of America Nova (being restored), 1973 Nova Custom, 1977 Nova, 1973 Nova (Pro-Street someday), 1968 Chevy II (Garage Find 2012)
http://www.youtube.com/user/StlNovas/videos
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: Trunk mounted battery cable size.
Location
Location
First Name
Human Verification
