Help with alternator conversion (car won't shut off)... - Team Camaro Tech
Thread Tools Display Modes
Old Jun 8th, 02, 04:29 PM
ohayden ohayden is offline
Default
Well... I did the conversion that I found in the tech ref section: http://www.camaros.net/techref/ftecref14.html
I know I did not wire it wrong (at least not according to the tech ref). I wanted a cleaner engine compartment and I'm just so nit picky, so I removed the blue wire altogether, and re-routed the brown wire (just like the author of the tech ref). Anyways... to keep it simple... if I pull off the brown wire it works fine. If I have the brown wire connected then it won't shut off. I know the brown wire is a resistor wire that used for the gen light. I did not cut the wire whatsoever, just rerouted. I am running a complete MSD ignition setup. I'm using the 6A box with the MSD 3 coil. The alt is an Autolite PRO-TECH 7273. Could the alt have different terminals? Would it hurt if I try to put the brown wire on the #2 instead of the #1 terminal?
I knew of someone who had the same problem and they claim it was because of the MSD but I don't remember what they did to solve it.
Any help would be great!
Thanks,
Ohayden
http://www.350ss.com
1967 Camaro (Toy)
1968 Camaro (Week End Car)
1973 Camaro (Daily Driver)
[This message has been edited by ohayden (edited 06-08-2002).]
Old Jun 8th, 02, 07:15 PM
BTC BTC is offline
Default
If you converted to a single wire alternator I think you need to add a diode to one of you wires. The diode is like a one way valve for electricity. I had the same problem and the diode fixed it. It's been too long to rember which wire. Do a search or go to Mad Electronics, they have an explaination for this situation and will tell you what size diode you need.
68/Z28,35O LT1
RICHMOND 5 SP,
Old Jun 9th, 02, 05:39 AM
John_Muha John_Muha is offline
Default
It's caused by the alternator providing power to the MSD box after the key is off. Answer is a diode in the brown line. MSD now recommends a 400 volt 1 amp diode. Should be able to get one from Radio Shack.
Instructions are here:
Go to: http://www.msdignition.com/
Click on: Instruction Download
Click on: MSD 6 Series
Click on: MSD 6 Series Installation Instructions
Look on page 8.
Old Jun 9th, 02, 07:38 AM
Default
Great... that will be easy to fix. I read their install instructions and it's saying to use a 100v 1a diode with the band pointing towards the alt. So should I use a 400 or a 100 volt diode?
I will try it today! Thanks!
Ohayden
1967 Camaro (Toy)
Old Jun 9th, 02, 11:50 AM
Default
<BLOCKQUOTE>quote:</font><HR>Originally posted by ohayden:
Ohayden
<HR></BLOCKQUOTE>
Go with the 400 PIV diode. The 100 will work but some of their techs have been recommending a bigger size. If Radio Shack doesn't have a 1 amp, you can always go bigger (2 amp).
Old Jun 9th, 02, 01:53 PM
Default
Thanks BTC and John_Muha. That did the job. Radio Shack didn't have a 100 or 400 volt in stock so I got a 200 volt 1 amp diode and installed it and voila it actually turns off now with the key in the off position
Now my engine compartment looks cleaner and I now have an up-to-date alternator w/an internal voltage regulator. All around good deal!
Thanks again,
Ohayden
1967 Camaro (Toy)
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: Help with alternator conversion (car won't shut off)...
Location
Location
First Name
Human Verification
