Electrical & Wiring Troubleshooting electrical
Old Jun 11th, 00, 07:52 PM
67drake 67drake is offline
Drake
Question
I had a post out here a few weeks ago about my 67's intermittent no start problem.I thought after replacing the ignition switch my problems were solved,it hadn't done it for a week or so,where as before it was every day or two,but it happened again Friday.So while going over the wiring today I found a relay,that when disconnected,prevents the car from starting.It is right under the external voltage regulator on the core support.It has two "screw on"terminals,one is marked "batt",and has a red wire running to it,the other is unmarked,and has two black wires on it.It also has two "spade type" terminals on the bottom,each with a wire running to them.Any ideas?What is this called?I find no reference to it in any of my manuals.It appears to be quite corroded,I cleaned up the terminals the best I could hoping this would at least help temporarily,but it looks original and should be replaced.I suspect this MAY be the problem.I just want to know what it is so I don't have to walk into the parts store and ask for that "gizmo" on the core support.Thanks,Drake
67 RS RAGTOP # matching,
4X4 CHEVY TRUCK
[This message has been edited by 67drake (edited 06-11-2000).]
Old Jun 12th, 00, 04:49 AM
camcojb camcojb is offline
Jody
Post
It sounds like the horn relay although on my 72 it is on the firewall. I'm sure someone can tell you for sure.
[This message has been edited by Camcojb (edited 06-12-2000).]
Old Jun 12th, 00, 06:57 AM
CA420 CA420 is offline
Post
Yep, that's the horn relay.
68 RS, Ash Gold,pwr windows,Hounds tooth
Old Jun 12th, 00, 07:24 AM
Drake
Thumbs up
Really?Why do they have this tied into the ignition?
BTW,thanks!
4X4 CHEVY TRUCK
[This message has been edited by 67drake (edited 06-12-2000).]
Old Jun 12th, 00, 11:44 AM
gheatly gheatly is offline
Post
It's tied into the ignition so that the relay will buzz when the car is off and you leave your keys in the ignition switch. You know, the sick cow mooooooooooooooo.........
[This message has been edited by gheatly (edited 06-12-2000).]
Old Jun 12th, 00, 05:08 PM
RickD RickD is offline
Team Member
Post
It is indeed the horn relay. The small lead off the positive battery terminal goes to it, then feeds the rest of your electrical system.
Old Jun 12th, 00, 06:59 PM
Drake
Thumbs up
Thanks guys.I got a new one today,in stock for $9!I HOPE this solves my no start problems!
4X4 CHEVY TRUCK
