Electrical & Wiring Troubleshooting electrical
Old Mar 14th, 00, 06:34 AM
rustorator rustorator is offline
Question
I'm in the process of restoring a '68 Camaro convert. and have replaced the original style alternator with a one wire built in regulator. My question is what wire goes where? I have a wiring diagram, but it doesn't show enough detail. The horn wasn't connected when I bought the car, it didn't even have the relay in so I have nothing to go by. After wiring up the alternator there seems to be only three wires left that could possibly hook up to the relay. One is dark green (wire from horns), one is pink with a black stripe and one is black. All three have female connectors. I noticed there are two screws labeled (battery). Can anyone tell me how to hook this thing up? Thanks, this site has been a great help for my resto. project!!
Old Mar 16th, 00, 06:05 AM
JimM JimM is offline
Jim
Post
Hey rusterator, The horn relay is used as a junction block for some of the hot wire supplies. the old regulator is right in the same area, too. I put a one wire on a '67 15 years ago, but the memory is kinda foggy. I'll eyeball my '68 ragtop tonight and get back to you.
Old Mar 16th, 00, 10:52 AM
Post
Thanks Jim, hope you can help. Don't want to fry anything.
Old Mar 19th, 01, 12:53 PM
convertibleRS convertibleRS is offline
Tech Team
Post
The black wire should be the wire that runs from the horn button in steering wheel. It attaches to one of the two prongs at the bottom of the horn relay. The green wire, I believe, runs out to your horns. There should also be a red wire, which comes from the battery and gives the relay power. Mine also has a black wire that runs from the relay to a connector on my firewall. That supplies power to my Rally Sport lights, so if you don't have an RS you won't have that wire.
The red wire that attached to your original alternator is connected to the red wire that attaches to your horn relay. So basically, this red wire runs from your alternator to your battery, with a junction at the horn relay.
I have a one-wire alternator, and just used that red wire. The other wires that went to your alternator were from you external regulator, and don't need to be used anymore.
Hope this made some sense..
Old Mar 19th, 01, 02:39 PM
TOMSTV TOMSTV is offline
TOM
Wink
here is a drawing i made up of were the wires go on the relay.it shows what color goes where. this is from a 69 camaro. hope this helps. http://albums.photopoint.com/j/view?...034&p=44213543
There are five colors
black/red
red
a large red
green
black
[This message has been edited by TOMSTV (edited 03-19-2001).]
Old Oct 20th, 01, 02:53 AM
englemac englemac is offline
Post
I was hoping to see TOMSTV wiring diagram, but I guess it has been removed...
Can someone fill in the blanks for me?
'69 Horn Relay:
Black wire (slide on connector)- from the horn button to relay
Green wire (slide on connector)- from the relay to the horns
Red/black stripe wire - ??????
Large red wire - from pos batt terminal to relay at screw in connector on relay.
Small red wire - from screw in connector on relay to ??????
Am i right on everything else?
THANKS!!
Old Mar 26th, 06, 12:56 PM
cmarorally68 cmarorally68 is offline
Default horn relay
does any one have a picture diagram of the fornt end or the diagram that shows how the wires hook up on the horn
Old Mar 26th, 06, 01:05 PM
Jim
Default Re: horn relay
cmarorally68, welcome to team camaro!
The picture and description you are looking for is in a sticky called "what it is, Where it is" at the top of the electrical forum. If you search for "color wiring diagram" by user "69er", you will find some slick color pdf wiring diagrams. These diagrams are also for sale cheap in the forum classifieds.
How in the heck did you pull up a 6 year old post to put your question in?
68 SS (clone) Vert, #'s matching 383, TKO500, Holley EFI
04 Silverado SS The Black Beast
93 Polo Green Corvette
http://www.Jimragtop.com
Jim's NEW Blog!
Jim Cam
