How to get to the wiper switch - Team Camaro Tech
Old Jan 13th, 03, 05:45 PM
rickmack rickmack is offline
Default
Hello,
Does anyone have an easy way to get to the wiper switch on a 1968? I need to check the ground.
Rick
Old Jan 14th, 03, 02:46 AM
choptop's Avatar
choptop choptop is offline
Scott
Default
Without removing the instrument cluster there is no easy way to access the wiper switch. I had to lay on the floor board and thread my arm up behind the dash to swap mine out. A real PITA.
I suggest removing the instrument cluster...
See my '68 RS/ZZ4
Old Jan 14th, 03, 05:17 AM
Default
That's not what I wanted to hear!
Old Jan 14th, 03, 08:10 AM
choptop's Avatar
Scott
Default
Sorry...
See my '68 RS/ZZ4
Old Jan 14th, 03, 05:24 PM
Geezer Geezer is offline
Default
I don’t recall that the wiper switch needs to be grounded but if it does, it would ground to dash via the switch housing and the nut on the face of the dash behind the knob. Don’cha think Vern?
Geezer
Old Jan 14th, 03, 10:04 PM
68rs406 68rs406 is online now
Sean
Default
the wiper switch does in fact use its own body to dash connection as the means of grounding. there is one of those star washers (at least on mine there was) on the switch where it contacts the dash, i imagine to help the continuity of the ground. when i bought my 68, the switch was not working, and when i looked into it it was just not tight to the dash and there was a bit of surface rust hampering the connection, check that out on yours. w/o a good ground the switch wont work right. good luck, hope that helps
Old Jan 15th, 03, 05:51 AM
Default
I will try that. I am pretty sure it's a ground problem. When I turn the car on, the wipers turn on and stay on, no matter what position the switch is in. The motor has one dual spade connection and on single spade. I do not have anything hooked up to the single spade, what is that connection used for?
Old Jan 15th, 03, 10:21 PM
Sean
Default
i can't recall what the wires did in particular (it's been awhile since i messed with it) but i think that missing single spade connection may be a culprit to your problem. on mine the dual spade has a yellow (which i believe is primary power) and a light blue wire, and the single has a black wire, all factory harness. i think the single (black) connection is a speed function, but i can't recall. i know someone on here has a wiring diagram that can tell for sure. is your harness other than factory? could be some swapped wiring too.
Old Jan 16th, 03, 03:34 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default
This is from assembly manual, hope it helps.
.... Jim aka Click
69RS 350/255 LM1, TRW forged pistons, .30 over, TH-350 auto.,
Dover White, Blue Vinyl top, F&R spoilers, am/fm, 3.08 Posi.
A/C, fold down rear seat, Pdb, PS, Cowl Induction, Endura Bumper
My RS.. www.brainerd.net/~knudsen/69RS
Old Jan 16th, 03, 05:11 AM
Default
Thanks for the responses. I'm a little unsure what the wire diagram tells me. Where does the single line actually go?
