Site Discussion Website questions, comments, suggestions and tech help.
Old Feb 16th, 03, 05:31 AM
BBCamaro BBCamaro is offline
Default
hey i have my hobbystage site address under my signature but it shows so you have to manually type it in to go view it, how do i make it so it will show in blue so you can click on it and it will bring you there automatically, thanks
jake
1968 Camaro convertible, 454,th400,3500 stall,9 inch 3.55 trac loc
http://hobbystage.net/camaro/bbcamro
Old Feb 16th, 03, 07:03 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default
http://www.hobbystage.net/camaro/bbcamro
did this work? If so, you forgot the WWW
Old Feb 22nd, 03, 08:13 AM
Snatchin'gears Snatchin'gears is offline
Post
I'd say while doing a post use the instant UBB code feature and add a link to your site. There are two stages. Clcik the URL then paste in the whole address then click OK. Then write the text you want to use for the link then click OK. Then the entire link will be posted in your reply box you originally post in. Drag the mouse over the text funny brakets and all to turn it all blue then right click the blue and select COPY. Then open another window and access you section for adding your signature and right click then PASTE where you want it in your signature. I say open another window in case there are problems getting it right so that you can try again. There might be a need for a space before and after the entire html tag stuff so have fun.
Old Feb 22nd, 03, 04:13 PM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Post
I just plucked the URL right from his post and plopped it down in this one and it came up as a clickable (no pun intended) link. I didn't do anything but COPY & PASTE.
Go figure...
Here I just used the Instant UBB Code and typed it in, then for the name I typed it in the exact same way.....
Then I added it to my Sig by just copying and pasting the exact same URL under the rest of my sig stuff. See the bottom of my post..... you must have just made a typo BBCAMARO. I looked at the source code for your original post and I can't tell what happened.
...'69 Camaro
http://streetmachinesofrochester.com/main.htm
Old Feb 23rd, 03, 03:19 AM
Post
thanks guys, it worked when i put the www in the address, i did not know it would still work if i did that , thanks
jake
1968 Camaro streetfighter, 18x10,18x12 ccw's,tq arm rear,apex c6 front sub,ls6 asa cammed dry sump,t-56,335/30/18 and 275/35/18 toyo r888
www.jakesrodshop.com
Jake's Rod Shop
207-595-0677
