Old Jul 10th, 00, 07:33 PM
backfire backfire is offline
Post
Are the mounts for factory shoulder belts present in a car that didn't come from the factory?
Old Jul 11th, 00, 08:10 AM
Chris Edwards Chris Edwards is offline
Post
it wasnt even a option in 67, lap belts were the only way. so no , theres nothing to bolt a shoulder restraint to . maybe some fancy welding in the sail panel area could do the trick, but I havent seen one.
Chris's 67 RS can be seen at http://www.geocities.com/macphreak4evr/index.html
JOIN THE CAMARO NET WEBRING! www.geocities.com/macphreak4evr/webring/webringjoin.htm !!!
Old Jul 11th, 00, 03:07 PM
Post
I'm not sayin your wrong but in the Camaro Restoration Guide from MBI publishing, Appendix B page 280 shows that code A85 is for Custom Deluxe Front Shoulder Belts in the 67 Camaro. Price was 26.35 and was put into 894 67 Camaros.
Old Jul 12th, 00, 04:25 PM
Mike67cam Mike67cam is offline
Tech Team
Post
Backfire:
I have the headliner out of my 67 right now and there are two threaded mounting holes per side where the shoulder harness would mount. My car doesn't have the factory shoulder harnesses. The mounts should be in every car.
http://members.aol.com/mknopp
Old Jul 13th, 00, 07:51 PM
sixtsevnssrs sixtsevnssrs is offline
Tim
Post
My 67 has them as well.
Tim
67 ss/rs, MODIFIED
Tim's Homepage
AOL-IM = sixtsevnss
Old Jul 14th, 00, 05:20 AM
Post
Guess I spoke before I looked,
I fall back in to my DA/SS Catogory.
Old Jul 16th, 00, 02:28 PM
94Harley 94Harley is offline
Thumbs up
My 67 RS/SS has factory shoulder belts w/ retainer clips. This is a factory option for 1967. The difference from 67 to 68 was the clips that hold the belts up against the headliner.
Old Jul 20th, 00, 07:05 AM
withnail withnail is offline
Question
Does anyone know where you can get hold of the clips for holding the shoulder belts to the roof?
My '68 has the mounting points under the headliner and I have the belts but nothing to clip them up out of the way when they're not in use.
