how do I remove my 68 dash pad? - Team Camaro Tech
Thread Tools Display Modes
Old Dec 28th, 04, 05:37 PM
68RSdroptop 68RSdroptop is offline
Post
I need to replace the dash pan under the pad and the dash pad for that matter, how do I remove the dash pad? I removed the screws in the front, now whats holding it on?
Old Dec 28th, 04, 05:49 PM
phoenixdawg phoenixdawg is offline
Post
I can't remember all the process, but if you go to SuperChevy's website I believe they have a complete tech article on removal of the dash pad for a 68 Camaro
Old Dec 28th, 04, 06:02 PM
Eric Kammerer Eric Kammerer is offline
Post
The below is quoted from TC member Kyvox in a thread in November...
"There are 4 nuts securing the pad that are accessable from under the dash. Pull the glove box, drop the steering column, pull the guage cluster to get at them. Also two pins at the bottom of each arm that are pressed into spring clips in the dash. These can be a PITA to get out without messing up the pad."
I will add that the nuts under the dash are the thin sheetmetal type, and are also a PITA to get to. You'll be on your head, balled up under the dash, getting your hands all torn up.
If the pad is in good shape, be careful with it (the repro pads are none too good). The arms running down the sides of the dash will break off at the top where they join to the main pad if you are not careful.
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old Dec 29th, 04, 04:30 AM
boodlefoof boodlefoof is offline
John
Post
ditto Eric's post.
On the press-in fittings at the bottom of each of the pad's "legs" I found it helpful to go from behind the dash and knock them out with a small hammer from behind. I started by just yanking on the pad... and it became clear that if I continued to do so it would get busted.
Old Dec 29th, 04, 05:15 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Post
Ditto
Those threaded tiny bolts are VERY long too. Not sure why as it serves no purpose that I can see. Reaching up under there and unscrewing those tiny nuts will leave you a stockholder in BandAid corp.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos of my Camaro for viewing
Old Dec 29th, 04, 06:01 AM
dukemd66 dukemd66 is offline
Rick
Post
if you want me to post some pics of the underside of the dash email me.
you will be able to see the fasteners
Rick
Rick
68 project...reassembly starting: (383, AFR 195, Air Gap, Comp Cam XR276HR, 1.6 CC Gold rollers, Holley 750, 4/09) (TKO 600 conversion from T350 4/09) (floor pan restored 6/09). (12 bolt 3.73, Wilwood disc, Hotchkis TVS 7/09), Dougs 368 with Big Dog mufflers (9/09), 383 fired up 9/30/09, Candy Apple Red 2012 with white RallyBee stripe
Old Dec 29th, 04, 06:11 AM
click's Avatar
Moderator .. Jim
Jim
Post
Good idea Rick, lets show some of those knuckle breakers. Maybe you have different angle pics too.
Old Dec 29th, 04, 11:11 AM
Rick
Post
some pics of a 68 dash and pad. Will give you an idea of where to look/feel for them. I had my dash components removed so it was very easy. only 4 nut/bolt combo and 2 push in tabs at the bottom of the pillars. Every other hole in dash used by fasteners. Just a rush job on pics at lunch...if you need better let me know
under "dash/pad"
http://photos.yahoo.com/dukemd66
Rick
Rick
Old Jan 2nd, 05, 12:16 PM
dschribs dschribs is offline
Post
Here's some help from a prior post...
Dan
'68 Camaro Convertible
http://community.webshots.com/user/dschribs
Old Jan 2nd, 05, 12:17 PM
Post
'68 Dash Pad
Dan
  #11
Old Jan 2nd, 05, 04:01 PM
JimM JimM is offline
Jim
Post
Dan, my '68 doesn't have that chrome strip around the pad, kinda like it, where'd it come from?
  #12
Old Jan 4th, 05, 02:47 AM
Post
Jim
It was an option in '68. You got it when Deluxe Interior was ordered or with the Z23 Special Interior Package (along with bright pedal trim, and a different steering wheel). It can be added but the pad will have to come off so it can be properly secured. There's one on E bay right now.
Dash Pad Trim
Dan
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Interiors      Current Topic: how do I remove my 68 dash pad?
Location
Location
First Name
Human Verification
