| Team Camaro Tech Current Topic: Seat belts | ||
| Interiors Upholstery & soft trim |
I'm installing seat belts in the back of my 69 camaro. I removed the rear seat, but I only see 2 pre drilled hole in the floor. They are toward the inside of the car by the drive- line hump. Am I missing the other two? The car must of had belts in it before because it has the shoulder straps above the L & R doors. Do I need to drill another set of holes or is my eye sight going? Please help. Thanks
The holes are up on the panel between the passenger area and the trunk - just below the edge of the seat back.
I only seen 2 holes. Both ends of the belt didn't attach in one spot did they?
The center belt shares the two holes with the outer belts. There are two holes toward the side panels that attach the outboard belts. You may have to remove the seat back to get to them.
------------------ Click here to see see my car and hear 5-speeds. http://www.geocities.com/casanoc |
I think I still have my drawing at home with the layout of my 68's rear belts. If you'd like I can scan it and send it to you via e:mail.
don |
Thanks guys I found them both. The other two hole were hidden by the seat.
