Difference in horn/wheel parts, Tilt vs Non tilt for a 3-spoke wheel - Team Camaro Tech
Old Nov 26th, 03, 08:16 AM
69rad 69rad is offline
Post
On a 69:
When installing a 3-spoke Rosewood or Cushion-rim/"Comfort Grip" sttering wheel.
What parts are different between tilt and Non-tilt steering columns?
I just bought a complete Original Cushion-rim/"Comfort Grip" wheel assembly (Hub, horn kit, Buick Horns button, don't worry I'll replace the Buick horn cap). My guess it is for a standard column, but I don't know that for sure.
My car is currently standard column but I would like to install a tilt someday. I plan on installing this wheel right away, because it will look so cool sitting in the garage all winter.
What parts will I have to buy when I do get a tilt column?
69rad
69 350 4spd. Convertible
Cowl Inducted LT-1 with full Instrumentation
Old Nov 26th, 03, 05:48 PM
Geezer Geezer is offline
Post
I vaguely remember something about the turn signal lever having a slightly different bend, but I think that’s it.
Ron
The “Junk Yard Dog
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Old Nov 27th, 03, 03:38 AM
Unreal Unreal is offline
Gary
Post
I switched to tilt, and when I was at Ricks, I looked at the two levers. they are a slightly different angle, so rather than buy a new one, I bent mine a little by putting the flat end in a vice and tweaking it. Can't remember which way I bent it, though. When installed, the two levers should be parallel. Other than asthetics, I saw no reason for the different turn signal handles.
Old Nov 27th, 03, 03:49 AM
DjD's Avatar
DjD DjD is offline
Dennis
Post
From the aspect of mounting the wheel, nothing...
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Nov 30th, 03, 01:49 PM
Post
But what about the horn parts?
All the repro sources list 2 different mounting/horn kits. One for tilt andone w/o.
What pieces are different?
Anyone know, and is it only for the functioning of the horn?
69rad
Old Nov 30th, 03, 02:29 PM
DjD's Avatar
DjD DjD is offline
Dennis
Post
Ok - I did some research and remembering a small problem I ran into years ago installing my cushion grip wheel, maybe I got the wrong kit... I ended up using the canceling cam that was in my tilt column when I removed the std wheel. The one provided in the kit wouldn't fit properly on the steering shaft. It fit over the shaft but didn't seat properly.
The AIM doesn't show a difference when mounting a plastic rim, 3 spoke wheel to a tilt or std column. I think the factory didn't see the canceling cam as a steering wheel mounting part like the repro kits do...
At the time I wrote off the cam as a poor repro part... When I bought the kit I wasn't asked if I had a tilt wheel...
...Dennis
White Wonder
The Nova
Photo Album
