| Team Camaro Tech Current Topic: Console Autometer gauges | ||
| Interiors Upholstery & soft trim |
I have the pictures posted on the web thanks to help from a fellow member. Check it out.
http://www.midnight-auto.com/contrib/gauges.htm |
pretty spiffy. did you ever figure out if you could replace the tach and speedo(clock too?) with the same gauges to make everything look the same?
------------------ To see a pic of my car, click here... pages.prodigy.net/mtbmtb/rf396ss.jpg |
Looks good - I just put some in my car too. I had already their 3-guage pod (black on black) that was mounted under my radio so I just pulled those guages and installed them. I like the all black look. I plan on adding Auto Meter's 2 1/8" tach in the remaining hole.
One question: Did you have to ream out the guage holes so the guages would fit? |
Mike - not yet. I know the 3 3/4" will fit, I just haven't quite figured out how to make it look "factory". Couple more beers and I might figure it out yet.
Kevin - I didn't have to alter anything. They fit good (a little snug due to mold flashing in the holes). |
I'm looking at adding the console guages to my 69. Did your new guages come with or without the other mounting necessities?
DPESQUIRE - Everything needed is included. The gauges even came with green covers for bulbs to match the rest of interior lights. Came to $206 from Summitt (all electric gauges). Search for the previous post for part numbers - if you can with the new web site. If not, let me know and I will repost.
jm69ss - That sounds great. I checked my current Summit book but didn't find the console guages listed. I also tried searching for your former post, but didn't come up with numbers for the console guages - just the speedo and tack (probably my computer skills!). Could you post the Summit numbers for the console guages? Thanks. DP.
DPESQUIRE - No problem. Gauge housing # ATM-10002, water temp # ATM-4337, oil pressure # ATM-4327, voltmeter # ATM-4391, fuel level # ATM-4314.
James |
James, thanks for the info. I'll check it out. From the picture, I'd say the guages look real good.
Will this setup work in a 67 console?
