Old Aug 8th, 00, 11:03 AM
gldn slmbr gldn slmbr is offline
Post
Is there a tool or just a trick to removing the window crank clips??
Sean
68 327 conv.
Old Aug 8th, 00, 12:59 PM
mccorry's Avatar
mccorry mccorry is offline
Steve
Wink
There is a tool...but it isn't too hard to get them off with a curved tip seal pick. You can buy a set of picks at most any autoparts stores...
Steve
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my car ---> www.mindspring.com/~mccorry(updated 7/1/00)
Old Aug 8th, 00, 01:04 PM
CA420 CA420 is offline
Post
They do sell a tool for that but I have also used a flat screwdriver. Everybody sells the tool, Autozone, Pep Boys etc. Looks like a big black snake tongue with a bent up end on it for trim removal. They are usually over by the " HELP " odds and ends shelf, you know the one with the master cylinder gasket, door locks, vacuum plugs.
68 RS, Ash Gold,pwr windows,Hounds tooth
Old Aug 8th, 00, 02:26 PM
Post
Thanks for the help!
Sean
68 327 conv.
Old Aug 8th, 00, 06:42 PM
Austin Austin is offline
Post
You can get it off like mentioned above without buying the tool, but run the risk of damaging the door panel. Another way to remove the C-clip with out the proper tool is a shop rag.
Take the shop rag and wrap it around the base of the window crank. Then work the shop rag back and forth (like drying your back after a shower) the rag will grab the edges of the clip and pop it off without the risk of damaging the door panel.
Austin
Old Aug 8th, 00, 07:04 PM
69er 69er is offline
Post
I would buy the tool. They are very inexpensive and then you'll have it the next time you pull the handles off.
Old Aug 10th, 00, 08:08 AM
Brad74 Brad74 is offline
Post
I always take a piece of safety wire (same thing as electric fence wire) and bend it into a small hook on the end. You can then fish the clip out with the hook and pull out the clip. I always pull the wire with pliers.
Brad
