Old Jul 27th, 00, 11:38 AM
Ricks427 Ricks427 is offline
Tech Team
Thumbs up
Does anyone know how to get the key tumbler out of the ignition switch? 67/68
Old Jul 27th, 00, 12:28 PM
CA420 CA420 is offline
Thumbs up
Put your key in and turn to ACC, then put a paperclip or something small in the little hole next to the key ( you will know when you see it )and push in. You will feel it push a catch inside then turn your key all the way to the left ( I believe ) and it should come out. Then you can remove the bezel etc. The assembly manual describes this better.
68 RS, Ash Gold,pwr windows,Hounds tooth
Old Jul 27th, 00, 12:36 PM
memcgraw memcgraw is offline
Post
CA420 has it right. I butchered one before I figured it out....if I only would have found this site sooner.
Mark M.
Red 67 Convertible
Red Deluxe Interior
383/Tremec 5 Speed
4 Wheel Disk
Old Jul 28th, 00, 03:47 PM
Tech Team
Talking
Thanks guys! It was out 2 minutes. I figured it was something easy.
Thanks Again
Old May 21st, 01, 08:39 AM
Notorious Notorious is offline
Question
How about if you don't have the original ignition key? Do I have to have one made so I can change the lock cylinder?
Old May 21st, 01, 12:50 PM
Post
If you had one made why would you need to change it? Maybe a lock smith could get it to turn for you so you can change it out and even rekey it for you if you want.
68 RS, Ash Gold,pwr brakes,pwr windows,Hounds tooth,355/T350,3200 stall Dynamic converter,3.31:1 posi,Autometer guage pod
Old May 22nd, 01, 06:00 AM
Post
I know, sounds silly to have a key made so I can change the lock for a new key. But the thing is-- I had to buy locks for the doors and trunk anyway because they were missing.
