Old May 8th, 00, 11:24 AM
Ken67SSRS Ken67SSRS is offline
Default
How does one properly prepare (prime) and color interior plastic pieces? Specifically, I want to repaint/dye the kickpanels and seatbacks (original metal) on my 67 in Bright Blue.
Thanks!
Old May 9th, 00, 06:10 AM
ragtopman ragtopman is offline
Jim
Default
The most important step is the first step, you need to give the part a 'tooth' so the paint will stick. As far as the seat backs go(and the easiest)all I did was glass bead them cause you dont want to destroy the texture of them, spray a zinc enriched self etch on it them follow up with normal refinish procedures. The kick panels are some what the same. Im going to lightly glass bead mine(Ive done this with plastic grills before and seems to work)so as to give it a tooth, use a plastic cleaner to clean it, plastic adhesion promotor and a urethane sealer with a bit of flex additive in it, and then depending on what paint you use(Ive got DuPont)tell the paint people that you want it for interior use. The color should be made with a vinyl resin. If you use a scotch brite to give your kick panels a tooth, go easy on them. you dont want to destroy the texture of them.
Jim
Old May 12th, 00, 05:25 AM
Chris Edwards Chris Edwards is offline
Default
is there a type of Vinyl primer for vinyl paint? I just did all mine and it turned out great , but I cleaned the parts very well prior to giving them a fresh coat. it stuck great.
Chris's 67 RS can be seen at http://www.geocities.com/macphreak4evr/index.html
JOIN THE CAMARO NET WEBRING! www.geocities.com/macphreak4evr/webring/webringjoin.htm !!!
[This message has been edited by Chris Edwards (edited 05-12-2000).]
Old May 14th, 00, 11:07 AM
white rs/ss white rs/ss is offline
Tech Team
Default
Try using vinyl spray made by SEM = got mine at the auto paint store. Just wipe the kick, seat, or plastic down well with lacquer thinner and spray. I've used it for years, and it lasts for years.
[This message has been edited by white rs/ss (edited 05-14-2000).]
