Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
Old Aug 16th, 01, 06:02 PM
Unreal Unreal is offline
Gary
Post
I notice that Rick's new catalog lists a Molded fiberglas insulation pad, rather than the blanket type insulation.
Were the originals molded, or flat? They're quite a bit more expensive than the older style, but probably worth it if it would be correct.
Thanks,
Old Aug 20th, 01, 01:09 AM
Gary
Post
Anyone know about this?
Old Aug 20th, 01, 03:35 AM
twosxe1 twosxe1 is offline
Tech Team
Post
I would like to know also?? will check out
Old Aug 20th, 01, 06:14 AM
shaugs shaugs is offline
VINTAGE CAMARO
Post
I have purchased them directly from manufacturer REM. They are very close to the original. A couple of years ago I was looking for an NOS one for my 67 L78 and was quoted a price 1200. The are real nice, certainly worh the $65.
Old Aug 20th, 01, 06:22 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Post
When you guys say molded I think of hard plastic or rubber. Insulation is like a cloth more than plastic. Can you point me to a sample pic of provide further discription?
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
Old Aug 20th, 01, 06:47 AM
VINTAGE CAMARO
Post
The matt type of material compressed in different areas around the air cleaner lid and by the battery. This allow for clearance requirements of those components. This how the way the originals were fabricated.
Old Aug 20th, 01, 10:33 AM
gheatly gheatly is offline
Post
DjD - you can look under the hood of a new car. The mat seems to be made of a similar material, but is a little stiffer to conform to the irregularities on the underside of the hood.
Old Aug 20th, 01, 11:14 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Post
I'll pop the hood on the 2000 Impala this evening... They were not actually that way back in the 60's though were they?
...Dennis
"The Club"
Old Aug 20th, 01, 12:29 PM
JohnZ JohnZ is offline
Team Member
John
Post
No, they weren't. Originals were die-cut flat blankets, not molded. The new molded replacements are "car-show pretty", but aren't correct. The ones on most new cars are molded, as there's almost no clearance under the hood to anything, and they need all the packaging space they can get.
JohnZ
'69 Z28 Fathom Green
Old Aug 20th, 01, 06:55 PM
Gary
Post
OK, so Shaugs says the originals were molded, and John Z says they were die cut fiberglas insulation. Which is correct?
The molded ones basically are the same material as the die cut, except they have a heat set binder in them, so when they are hot pressed, the binder kicks in, and the materila holds it's shape.
Old Aug 20th, 01, 07:24 PM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Post
No disrespect to shaugs but John was an engineer involved with the 1st gen when it was in production and I was fairly sure but being polite when I asked...
...Dennis
"The Club"
Old Aug 21st, 01, 05:05 AM
clill clill is offline
Gold Member
Charley
Post
Ahhh, but everyone knows that Engineers get
Senile from being away from Production lines. Unreal..Shaugs does not say that they were Molded, he says the were compressed. Ricks says they are Molded. I think we are all thinking the same thing, not quite sure what that is though.
Old Aug 21st, 01, 08:56 AM
VINTAGE CAMARO
Post
I have a survivor car, with the original insulation. I described what the original and the new reproductions looked like. John is more the authority on the details. My point is that in my oppinion they are dam close... and for the price they are perfect.
Old Aug 21st, 01, 09:34 AM
pipeman pipeman is offline
Post
I guess a good answer to the insulation question would be " Did heat press or whatever is being done to the current pads even exist in the 60's"
69 rallye green X77 Z/28,1967 SS 396 Conv. 1974 c-10 454 swb
Old Aug 21st, 01, 09:49 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Post
So an origional should have a round indent to allow more clearence for the air cleaner? Why an indent for the Batt? I paid less than $25 for my repop blanket and clips.
