Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
Old Aug 25th, 01, 01:19 PM
badcam badcam is offline
Tech Team
Post
are there any 2nd gen f-bodies that were equiped w/3.23:1 gears in the diff? i want to swap in an axle already equiped with these gears. thanks for the help.
Old Aug 25th, 01, 04:00 PM
the mechanic the mechanic is offline
Chris
Post
you can find stats on all the 2nd gens at www.nastyz28.com , its basicly just like this site only geared directly to 2nd gens.
chris
1980 Z/28
(under construction)
Old Aug 25th, 01, 06:21 PM
NastyZ NastyZ is offline
Post
Since I own the above site I'll save you some time searching.
Not to my knowledge. In the camaro at least. I don't know if the firebird used a 3.23 during these years.
3.23 camaro usage 1st shows up in 1990 (a 3rd gen)
During the 70's, you could get a 3.31, 3.36, 3.42 and 3.08 (in the range closest to what you seek).
The 3.08 and 3.42 are (semi)common gear ratios for 2nd gens. The 3.31 and 3.36 are less common, since they're 1970 only gears, used in either the 8.2" 10 bolt or the 12 bolt rear end.
I say semi common because only Z28's will have the 3.42, or a high altitude car will have a 3.08, or someone used the "rare" performance axle ratio option in a base car to force a higher (3.42) gear into the car.
Typical 2nd gens have 2.73 (6 cylinder) or 2.56/2.41 rears (V8 sport coupe).
Old Aug 25th, 01, 10:13 PM
travis travis is offline
Post
A lot of late 70's buick V-6 equipped trans am's came with 3.23 gears. I think it was the standard axle for that particular engine.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
Old Aug 26th, 01, 10:38 AM
big gear head big gear head is online now
Freddie
Post
I have had 1 second gen Camaro rear end that had the 3.23 gears and a posi. That is the only one I have seen.
'69 RS/SS396 pro street
427/4spd/9"
Byars Performance
High Performance Drive Train Parts And Service
www.lubedealer.com/biggearhead
Old Aug 27th, 01, 11:58 PM
my69gofast my69gofast is offline
Post
I bought a Camaro sec gen rear several yrs ago to swap into my 79 TA. It was a posi with what I was told are 3.23 gears. Seemed about right but I never actually verified ratio. After reading above, I will have to doublecheck since I was planning on using posi and gears for my 69.
Old Aug 29th, 01, 03:51 AM
mont1le mont1le is offline
Post
Yes the 3.23 gear was a Firebird,T/A,Formula thing,it was available from 77 up on the Pont. F-Body 8.5 rear.
68 Camaro SS 350 Convertible.
Old Aug 29th, 01, 09:46 PM
bravewink bravewink is offline
Wink
I got my 3.23 posi from an '81 Turbo T/A. Man what a difference from the 2.41's. Good luck searching.....
