Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
Old Sep 7th, 01, 06:01 PM
68RS400400 68RS400400 is offline
Post
I bought this subframe and was told it was for a 69. It seems to measure out ok but the rad support holes are small(about 7/8" i diameter). Does anyone know the explanation?
Apparently these holes should be about 1.25 inches. The solid bushings i got from globaltech won't fit in the holes and the guy there says i may have a 70's subframe.
Like i said it seems to measure out ok(am taking it off this weekend to measure properly).
Old Sep 7th, 01, 06:02 PM
Post
Sorry i forgot to put in the link to the pics. Here it is. http://www.members.home.net/vanislec...frame_pics.htm
Old Sep 7th, 01, 06:13 PM
djunod djunod is offline
Post
Do you have an assembly manual for the '69? Check to see if you're trying to put it together right.
On the '68, the bushing does NOT go into the hole in the frame, but into radiator core support.
David
Camaro - '68 327 Coupe, '86 Z-28 IROC 305 TPI
Corvette - '73 Mako Shark II, '79 L-82, '82 Cross-fire, '01 Coupe
Old Sep 7th, 01, 06:55 PM
Post
Gotcha , but what about the slop in the 7/8" hole where the bolt goes through the subframe? Is that for adjustment?
Old Sep 7th, 01, 09:04 PM
Post
I believe so...
I bought the bushing & hardware set, and then looked at a couple of different pages in the assembly manual to put mine back together (it really had some screwy setup from whoever "restored" it before).
David
Old Sep 8th, 01, 12:23 PM
JohnZ JohnZ is offline
Team Member
John
Post
The oversize hole in the subframe is designed that way for adjustment; fore-aft for fender-to-door fit, cross-car to be able to create a square hood opening.
JohnZ
'69 Z28 Fathom Green
Old Sep 8th, 01, 01:29 PM
Post
Thanks for all the help aqain guys!
