Tech 2002 General Tech questions from 2002
Replies ONLY, no new topics.
Old Jan 28th, 02, 04:48 AM
BIG GUY BIG GUY is offline
Tech Team
Lightbulb
I have a 406 sml blk that will be going in my 85 z28. it has 10:1 slugs edelbrock aluminum heads w a .510/.533 lift cam.Duration is 244/254 at .050 with 114 lobe seperation. I am using 1.5 rockers on the intake and 1.6 on the exhaust.What stall and gear should I be runnning in my weight car with street tires and do I have enough cam?
Old Jan 28th, 02, 02:42 PM
gene stills gene stills is offline
Lightbulb
With out more info,tire size,trans,and how much and where you drive it,will have a lot to do with what you need.A 355 to 373 gear with around a 2200 to 2500 stall is usually a good all around set up for a street car with a moderately sized cam.
69 Camaro SS 350 4 speed
86 Monte Carlo SS
Old Jan 28th, 02, 03:05 PM
FrankP FrankP is offline
Post
A moderate cam for a 406 is 244-254 deg @50 .510/.533 lift?
Old Jan 28th, 02, 03:42 PM
boodlefoof boodlefoof is offline
John
Post
that is a pretty manly camshaft. What does the manufacturer suggest as far as a converter? I would guess it is around 3000rpm stall speed or more. As far as gears, again with that cam you are probably going to want to run some lower (numerically higher) gears. 4.11s would be nice, but a pain if you ever want to take it on the highway without an overdrive trans.
Old Jan 28th, 02, 03:51 PM
Post
ja and if he has a 700-r4--first will be about useless with 4.11s.
Old Jan 28th, 02, 06:23 PM
golopogos golopogos is offline
Post
4000 stall 3.89 gear, and if you want the overdrive go with the 4L60, or 4L80
Old Jan 29th, 02, 04:08 AM
ryanman250 ryanman250 is offline
Post
My dad has a really close setup to what your explaining and he runs a 4000 stall and a 4.56 gear with 28" tires and it does fine on the street and it rips on the track.
Old Jan 29th, 02, 06:00 AM
LoneStar68 LoneStar68 is offline
Tech Team
Post
ryanman250, have any idea what your dad's car turns rpm wise through the lights? I'm running a similar setup, but with 29" tires. I turn about 6300 @ 115.
Old Jan 29th, 02, 10:19 AM
Post
I called him and asked and he said about 6400 to 6450 but he said he just put a set of 29" tires and it now turns about 6250 to 6300. He can also cruise at 55 mph and it turns about 3000 rpm's with the 28" tires.
28" tires = 10.12's at 116
29" tires = 10.08 at 119
S-10 blazer with 406 and 4.56 gears turbo 400 with 4000 stall
[This message has been edited by ryanman250 (edited 01-29-2002).]
