Tech 2002 General Tech questions from 2002
Replies ONLY, no new topics.
Old Feb 3rd, 02, 08:31 AM
JayBird JayBird is offline
Question
I want to buy a mini-starter that will clear 1 5/8 Hooker supercomps on my 69 camaro. What mini starter is the best for this. Powermaster, CSI, etc?
Jay
69 SS-350 4-speed
Hotchkis suspension
Old Feb 3rd, 02, 10:01 AM
Ramonchis Ramonchis is offline
Tech Team
Post
I have used both powermaster (about $150) from summit and also Summit's Protorque starter, also about $150. Both were in my 69 Chevelle to clear headers, and both can be used on 153 or 168 tooth flywheels. Both can be rotated on their base to clear headers. I would go with the Protorque because it is built stronger and has a better gear ratio.
My 68 camaro still has the original bigger starter with 1 5/8 Comp headers and no clearance problems.
summit starter part #SUM-820323
222ft-lbs. torque, 4:1 gear ratio, 10.5 lbs,1.9 horsepower.
or when i upgrade the one in my 68
summit starter part #SUM-820323-M
342ft-lbs. torque, 4.44:1 gear ratio, 9.5 lbs, 3.1 horsepower. $250
good luck and have fun.
Old Feb 3rd, 02, 11:41 AM
novaderrik novaderrik is offline
Post
take your pick. I'm pretty sure any of them will fit. I bet a stock high torque starter would also clear without any problems.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels
see pics here http://community.webshots.com/user/novaderrik
Old Feb 3rd, 02, 03:24 PM
vettefab vettefab is offline
Post
try a 99 chevy s-10 with a 4.3 starter. It works great and has a lot of torque. When you go to the parts store ask for the permanent magnet gear reduction(pmgr). It will be listed in the catalog this way.
Old Feb 4th, 02, 03:12 AM
Post
Thanks for the replys!
JayBird
Old Feb 4th, 02, 10:11 AM
67killerb 67killerb is offline
Post
Just a quick question about this subject. I've done searches and seen that some guys end up shimming the starter and some don't. Why is this? I want to use a mini starter, but don't understand why this turns into a job messing around with shims, when the starter bolts to the engine block itself. Why would the distance between the starter gear and the flywheel vary like that so you would need to shim it? Was this a problem with stock starters as well?
