Tech 2002 General Tech questions from 2002
Replies ONLY, no new topics.
Old Feb 5th, 02, 06:20 AM
camaroman7d camaroman7d is offline
Royce
Post
I saw a post here not too long ago agout a guy having trouble getting the clutch rod to fit in his 69. I am switching from auto to manual in my 69. I know a kid that is doing just the opposite in his 68. He wants to trade pedal assemblies, but from what I read I think they are different. Is this correct? or is the rod the only thing that is different? Please clear this up for me.
Royce
70 Camaro 385ci
69 Camaro (soon to be 6" rod 355 backed by a T56)
2000 GMC Z71
http://hobbystage.net/camaro/camaroman7d/
Old Feb 5th, 02, 07:03 AM
bretcopsey bretcopsey is offline
Post
I THINK the difference is the 69 pedal has a second hole for the rod attachment. For some pictures see
http://ourworld.compuserve.com/homep...ch_linkage.htm
This may also be of some help.....
http://www.camaros.net/forum/Forum7/HTML/001816.html
Bret Copsey
'68 Camaro base coupe
'92 Caprice wagon
'98 Malibu
Old Feb 5th, 02, 07:30 AM
Royce
Post
I will be running a t56 setup if that makes any difference. I guess I should go ahead and trade, since I will have no use for the autmatic/brake pedal.
Royce
Old Feb 5th, 02, 08:07 AM
Post
I think you're probably right. The T56 setup probably requires some pedal modifications anyway. You may want to check this link for some good advice
http://www.pro-touring.com/t56/index.htm
Bret Copsey
'92 Caprice wagon
'98 Malibu
[This message has been edited by bretcopsey (edited 02-05-2002).]
Old Feb 6th, 02, 02:18 PM
JohnZ JohnZ is offline
Team Member
John
Post
The second hole (upper - smaller) in the '69 clutch pedal is for a plastic bushing for the link rod to the clutch safety switch. The other (larger - lower) hole is for the clutch pushrod.
JohnZ
CRG
'69 Z28 Fathom Green
Old Feb 7th, 02, 06:03 AM
Royce
Post
John, will the 67/68 pedal assembly work for my 69? I will be making the trade this evening.
Royce
Old Feb 7th, 02, 01:36 PM
Team Member
John
Post
Don't know for sure - the pushrod hole is 3/8" lower on the pedal on the '67-'68 pedal, which is probably why the '69 pushrod has a bend in it and the '67-'68 rod does not.
JohnZ
CRG
Old Feb 10th, 02, 11:58 AM
68 RS 68 RS is offline
Post
My Classic Industries catalogue says that the clutch pedal will fit but the brake pedal is different. Since you are using the T-56 I'd start with that and maybe you can make it work. If not then the ones that do fit are only like $80.
...Ron
