Tech 2002 General Tech questions from 2002
Replies ONLY, no new topics.
Old Feb 10th, 02, 03:05 AM
bmann2 bmann2 is offline
Post
I need to purchase oil pan and waterpump bolts. Is there a web site that has all the sizes and specs for engine bolts, or does anybody know here? it is on a 73 400 sb
Old Feb 10th, 02, 10:32 AM
davidpozzi davidpozzi is offline
David Pozzi
Post
Summit sells bolt kits for oil pan, timing cover, water pump separate or you can get a kit for the whole engine.
You have your choice of bolt head style and either plated or stainless steel.
Any speed shop would have them too.
Whatever pan bolts you get, get the ones with a washer type head that will stay tight and not leak as easily.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327 Origonal owner. 69 Camaro Vintage Racer, 65 Lola T-70 Chev SB Can-Am Vintage Racer
Old Feb 10th, 02, 04:40 PM
novaderrik novaderrik is offline
Post
you could also hit the local boneyard and pull the bolts off an engine sitting in the mud, and probably pay nothing for it.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels
see pics here http://community.webshots.com/user/novaderrik
Old Feb 11th, 02, 09:14 AM
Racer#00 Racer#00 is online now
Wink
Yeah, stick'em in your toolbox. I always fill up with bolts when I go to the local u pull it yards.
Dean
Racer#00
67 Camaro (Almost done!)
76 Trans Am Stock Car
68 Dodge D-100 P/U
Old Feb 11th, 02, 09:27 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Post
<BLOCKQUOTE>quote:</font><HR>Originally posted by Racer#00:
<HR></BLOCKQUOTE>
I don't think stealing them was the recomendation being offered!!
Old Feb 11th, 02, 01:13 PM
Post
would any chevy sb have the same bolts? or do I have to find a 400 sb if I went the boneyard method?
Old Feb 11th, 02, 01:21 PM
68rs406 68rs406 is online now
Sean
Post
bmann2,i just finished w/my 400(406),and externally the're the same as any sb.(for the most part)bolts are cheap,just buy a good set of a.r.p's and youll be happier in the long run,they look good too.
Old Feb 12th, 02, 07:58 AM
Winch Winch is offline
Team Member
Post
I've been kicking around the same thing. For $63 bucks seems like you can buy a lot of standard grade 8 bolts from TrueValue. We just need to know all the sizes. If I can find that out, that's the route I'm going. If you find a source of the info let us know.
Good Luck
Old Feb 12th, 02, 10:47 AM
xodus921
Guest
Posts: n/a
Post
aren't they 1/4-20 bolts around the outside and on the ends I think they're 3/8.
Don't go to the speed shops they just tell you to go to true value and look at you like your a moron. I was trying to get the nice sets like ARP or something when I was asking.
Tony
<UL TYPE=SQUARE>
<LI>1979 Z-28, 350- Edelbrock Performer RPM Package- TH350
<LI>2000 Gmc Sonoma - 5-speed 4.10 rear[/list]
