Tech 2002 General Tech questions from 2002
Replies ONLY, no new topics.
Old Feb 10th, 02, 07:11 AM
daverichard daverichard is offline
Post
While filling up my 68 today, I noticed a pretty large amount of fuel leaking out on to the ground. It appears to be leaking from the filler neck. It is not a leak from the tank, because once I quit filling the tank, the leak stopped. I removed my license plate and found the rubber hose to be in pretty bad shape. Also, my fuel cap does not fit real tight anymore so I would like to replace the filler neck too. Can I change these without dropping the tank? Anything I need to be aware of while doing this?
Dave Richard
68RS/SS Convertible
L48 (350/295 Powerglide)
Old Feb 10th, 02, 07:30 AM
kel kel is offline
Post
Yes.
You should be able to change both without dropping the tank. The filler neck slides out through the opening in the back. You should be able to purchase both from any aftermarket supplier like Firewheel Classics here in our area.
All you need to do to remove them is losen the hose clamps on the hose and remove the screws from the filler.
Let me know if you have more quesitons. I had to replace mine a short while back.
Kel
North Texas Camaro Club
Is the glass half empty or half full???.....Neither, the glass is twice as large as it needs to be!
Old Feb 10th, 02, 07:37 AM
Thumbs up
Thanks for the help! This board is awsome. I posted a question and got an answer in 20 minutes. Thanks again!
Dave Richard
68RS/SS Convertible
Old Feb 10th, 02, 12:13 PM
Silver69 Silver69 is offline
Post
Don't be smoking or have any other ignition source around. Have the exhaust pipes be cool too. Try to have the tank empty. Remember, it is the gas vapors above the liquid gasoline that what ignites and flashes over.
Old Feb 10th, 02, 12:47 PM
FrankP FrankP is offline
Post
This may not apply to your situation but....
I had a '73 with the neck joint leaking where
it mates with the tank. I used some JB weld around the area and it sealed it up good.
Old Feb 10th, 02, 01:38 PM
ORENCH ORENCH is offline
Gold Member
Lightbulb
This may seem obvious, but notice that there is a hole behind the license plate, which gives you access to the lower hose clamp.
Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench
