Tech 2002 General Tech questions from 2002
Replies ONLY, no new topics.
Old Feb 11th, 02, 10:52 AM
jrager jrager is offline
Post
My aftermarket passenger mirror on my 69 does not bend in and up far enough to be of any use.
I purchased an OER passenger side mirror that was a bit better but still could not bend enough to see cars to the right of me.
I was thinking about modifying the mirror to allow it to bend a bit more but wanted to first check and see if anyone out there has tried this?
I think I can use a drimel to shave some of the mirror ball socket down. This should allow the mirror to bend more but I don't want the mirror to flop around if I cut to much.
If it works/or does not I will post the results.
Old Feb 11th, 02, 11:34 AM
rs1968ss's Avatar
rs1968ss rs1968ss is offline
Randy
Post
I did the same to mine and have had no problems.
-Randy
Cars:
<A HREF="http://www.camaroclubkc.com/rs1968ss.htm" TARGET=_blank>68 RS/SS BB ragtop
</A>RWHP: 329.4 RWTQ: 398.9
63 Nova II ragtop
Club:
Camaro Club of Kansas City
Old Feb 11th, 02, 01:21 PM
Gary Dorion Gary Dorion is offline
Post
What about installing the mirror forward alittle, maybe 1/8".
Old Mar 27th, 02, 03:51 AM
Default
Just wanted to let everyone know that I took a Drimel with a nibbler bit and was able to shave just enough off of the mirror mount shaft to allow the mirror to bend in a bit more. The mirror is angled perfect now and is actually useful.
The mirror when bent hides the area that I altered perfectly.
I can send pics of my modification if anyone is interested in doing this to fix their passenger side mirror.
Thanks,
My email is john.c.rager@xo.com
Old Mar 27th, 02, 06:07 AM
ORENCH ORENCH is offline
Gold Member
Default
Good job John, You just jumped ahead of me on this one, I was thinking about doing the same. Now I now it works, Thanks.
Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench
Old Mar 27th, 02, 06:15 AM
Default
<BLOCKQUOTE>quote:</font><HR>Originally posted by ORENCH:
<HR></BLOCKQUOTE>
ORENCH,
There was actually a mark on the ball shaft from where I was over bending the mirror before I ground it down. I used the mark as my guide to grind down the shaft. It only took a few seconds with my Drimel to notch the shaft so the mirror would be able to bend in a bit more. My modification did not loosen the mirror at all. You can't even see the mod when the mirror is bent in now.
In my case I just removed about 1/8th of the shaft or less and I was good to go.
Good Luck.
Old Mar 27th, 02, 07:33 AM
RickD RickD is offline
Team Member
Default
Great mod. Thanks. And you even get improved power-to-weight as a freebie!
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
