| Team Camaro Tech Current Topic: fuse panel clips | ||
| Tech 2003 General Tech Area from 2003 Replies ONLY, no new topics. |
Does anyone know where to get the clips that hold the fuses? I'd like to use new one's rather than used from a donor. Thanks.
Yank a fuse block out of something at the junkyard.
Otherwise, you can get that type of thing at an electrical supplier. Try this link..... http://www.autobodysupplies.com/Section6-Electrical.pdf Look at Page 200, Item 77-4699. The only problem is that they come in packs of 100 units! ------------------ Joe 1969 Wallet Crusher - HwyStar@Rochester.rr.com HwyStar's Garage! |
Try page 11 in their online catalog.
www.alliedelec.com Under Online Catalog go to Section Indices and click on Section 1. Fuse clips - 11 The ones in JC Whitney are for adding circuits to existing fuseholders. ------------------ '69 RS Camaro 355 5-speed 4.11 [This message has been edited by 1 2RUN (edited 01-08-2003).] [This message has been edited by 1 2RUN (edited 01-08-2003).] |
Thanks kgaffney & hwy star joe. I looked at jcwhitney but they weren't the type that inserts into the fuse block. I checked auto body supplies .com and #77-4699 is about the closest I've seen. I'm wondering if it has the retainer ears to keep it in the fuse block once it's inserted. I'll let you know. Thanks again Todd
Thanks 1 2 run. I checked and they are close but they don't seem to have the ears that snap them into place which keeps them from being pushed backwards when you try to insert the fuse. Thanks. Todd
Hi, I see you are in Fresno.
I just recently bead blasted and zinc plated mine. You really have to be careful removing some of those clips that have the extra accessory spade off to the side. Those clips right at the spade have a tendency to break the plastic detent hole out of the fuse block if they aren't extracted straight. I busted a couple chunks of plastic out on my first try and also made the mistake of cleaning the plastic with 409. The 409 took the white lettering right off the front of the fuse block. I ended up getting another hacked up wire harness on eBay, just to get another fuse block. I also taped off the wire harness connectors, put the whole wire harness in a hefty bag and bead blasted the wire females. Then, I held the wires over my plating kit and plated the terminals one-by-one with them still connected to the wires. A very tedious project to say the least. If you think you will ever make it over to San Luis Obispo in the near future, I can warm up my little zinc plating kit and plate the connectors for you. I have a full set of pictures of the fuse block restore on my hard drive at home too if you lose track of the placement of the wires. scottmoo@surfari.net [This message has been edited by bonecrusher67conv (edited 01-08-2003).] |
#11
Thanks bonecrusher. That's a tempting offer. I just don't want to remove the central nervous system right now. The car runs great, I just want to do a little preventative maintenance. I guess it's off to the wrecking yard with some wire cutters. Todd
#12
Hey Bonecrusher,
Do you have one of those little kits from Eastwoods? Have you used it for larger "cad plated" parts? How close do they look to silver cad? Thanks, Gary |
#13
It's the CopyCad plating kit from caswellplating.com
It uses a zinc anode plate, sort of similar to the cacrificial anode metal piece that might be found on a boat hull. If you buy Caswell's cheapest kit, they send you the instruction book that is pretty neat and in depth that covers their chrome plating instructions also (like 100 pages spiral bound). The size of the object plated is limited by the size of the power source. My 2 year old kit had a small AC transformer about the same size that I have for my computer speakers, but it was like on 2 volts DC output and that limits you to plating 16 square inches at a time. That is only a 2"x4" piece on both sides. You definitely need to start each session with a piece of scrap metal to scavenge the extra impurities that might be in the reuseable solution, because the first piece turns out grayish. Then after adding the provided clarifier solution, on the second or third batch the parts are a very bright silver color. Usually, by the 5th or 6th batch if additional clarifier isn't added, the plating starts to get dull again and grayish. The plating process really requires the solution to be kept at about 120+ degrees F or the process slows down dramatically. I have to fool my fish tank heater to keep it heating beyond its internal thermostat settings. The manual says you can by your own variable rectifier unit if you need to plate bigger parts if their supplied transformer is too small. [This message has been edited by bonecrusher67conv (edited 01-11-2003).] |
#14
Here is how the fuse clips look after plating: http://www.surfari.net/~scottmoo/fuseclip.jpg
#15
bonecrusher, did you get the cad-copy/Zinc kit. They have one for about $ 100. Do you get enough supplies to do everything you need to do on your car?
ps. pics look great. |
