Tech 2003 General Tech Area from 2003
Replies ONLY, no new topics.
Old Jan 15th, 03, 01:11 PM
67L48 67L48 is offline
Default
Since leaded gasoline is no longer available, do any of you use lead additives? Are there any dangers of using/not using lead additives?
Currently, I use premium (I think 91 octane) and a lead additive.
Thanks.
Old Jan 16th, 03, 06:21 AM
gheatly gheatly is offline
Default
If you are using later model heads, you shouldn't need the lead additive.
Old Jan 16th, 03, 06:43 AM
Default
My car was built in November 1966. The engine and other components were built in October 1966. Everything is still original -- #s matching.
K.A. Young
67 SS 350
PowerGlide AT
AC, Deluxe Interior
Daily Driver
Old Jan 16th, 03, 07:38 AM
BB69 BB69 is offline
Default
This question depends on how you use your engine. If you do a lot of driving at high RPM, you should have hardened valve seats installed. If you do mostly cruising, and don't put a lot of miles on the engine, a high quality gas with no additives should be fine. Some people have had problems with the additives leaving deposits on the combustion chamber and valves. I had the hard seats installed for about $180, while the engine was apart. Otherwise, I would not have torn the engine apart just for that reason.
Ken
69 RS, 427, 4-spd
69 Corvette Coupe, 427, 4-spd
Old Jan 16th, 03, 07:48 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Default
JMO but if the heads have never been off the engine and there is some mileage on it I bet the seats and valves are so coated from all the years of leaded gas that there would be no problem running unleaded without the additive. Now if the heads have been recently reworked and the seats were not replaced keep using the additive.
...Dennis
"The '69, the '96 our local club"
and the "daily driver"
Old Jan 16th, 03, 08:08 AM
bowtie-70 bowtie-70 is offline
Default
I always use a lead substitute in mine. I don't put on many miles and it is a stock engine but I feel that it is cheap insurance.
1970 mostly original
307,TH350
F41
Old Jan 16th, 03, 08:37 AM
stingr69 stingr69 is offline
Default
I am with Dennis on this one. A fresh valve job could benefit from a couple of tanks of leaded fuel. It is not that big a deal after that unless you do a lot of sustained high RPM driving. If your valve job is fresh, I would run a 50/50 mix of leaded racing fuel with unleaded premium for the first 2 tankfulls or so. After that I would not worry about it. Get some in a gas can from your local speed shop. They can not put it directly into your car.
-Mark.
Old Jan 16th, 03, 11:33 AM
Default
It only has 47,000 original miles on it and I add about 500 a year. Mild cruising, though I like to test the 350 on occasion. Sort of sounds like I don't need lead additives.
K.A. Young
67 SS 350
PowerGlide AT
AC, Deluxe Interior
Daily Driver
[This message has been edited by 67L48 (edited 01-16-2003).]
Old Jan 16th, 03, 03:39 PM
z28doug z28doug is offline
Doug
Default
<BLOCKQUOTE>quote:</font><HR>Originally posted by bowtie-70:
<HR></BLOCKQUOTE>
I agree with bowtie-70
Old Jan 16th, 03, 04:07 PM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Default
I forget the exact year (1976 maybe?) you couldn't get leaded gas at the pumps any longer but there wasn't a mass exidos to the parts store for lead additive. Even though they phased it out over time there were still a lot of cars on the road that ran fine once the leaded nozzle was removed for good.
Anyway I know what it's like worrying about "our babies" and understand wanting to be careful...
Old Jan 17th, 03, 09:02 AM
Default
I used leaded gas in my car, from the pump, up through at least 1992.
K.A. Young
67 SS 350
PowerGlide AT
AC, Deluxe Interior
Daily Driver
Old Jan 17th, 03, 09:44 AM
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
Default
Mr Young - I did a little digging and found that lead was banned from all gasoline after December 31, 1995 in accordance with the Clean Air Act Amendments of 1990. Unleaded came about with the introduction of the catalytic converter sometime in the 70's which is probably where I got 1976 from... I don't know for sure what year the cat was first used...
Old Jan 17th, 03, 06:56 PM
sunocospecial sunocospecial is offline
Tech Team
Default
Buy racing fuel in 55 gallon drums (Sunoco, VP, Union 76, etc.) if you need leaded fuel. You can mix it with pump fuel as needed.
Old Jan 22nd, 03, 01:28 PM
JohnZ JohnZ is offline
Team Member
John
Default
The "octane booster additives" all contain a healthy shot of ethyl alcohol, which does three things - 1) Eats the plating off the inside of the float bowls so corrosion can begin, 2) Eats regular rubber and cork gaskets and seals, and 3) Ethyl alcohol is hygroscopic (attracts water), which you don't need in your fuel system. Waste of money.
JohnZ
CRG
'69 Z28 Fathom Green
Old Jan 23rd, 03, 08:38 AM
DL DL is offline
David
Default
My '67 has a 305ci from a '76-'79 camaro.... I only drive it occasionally about 500-1000 miles a year, low rpm, no racing, just cruising..... At this time I use fuel with a lead-replacement, but I know that the leaded fuel is going to be banned soon here in the Netherlands (Holland). Can I just use the unleaded fuel when there is no leaded available? According to what I've read it is ok....low rpm, no fresh valve jobs etc. Engine is from 76-79 so it should drive ok on unleaded fuel.....
Can someone back this 'theory' up....thnx
David
I don't suffer from insanity.....I enjoy every minute of it!
'67 Camaro, blue exterior, parchment deluxe interior
Pics http://hobbystage.net/camaro/camaro_crew
