| Team Camaro Tech Current Topic: 96 LT-1 SWAP | ||
| Tech 2003 General Tech Area from 2003 Replies ONLY, no new topics. |
Has anyone out there put a 94 or new lt1 in a firtgen car.Can you let me know of any problems or other thing I might have to do.
Welcome,
Check this link out. There is a member here doing one now and another member from NY that has one. http://www.camaros.net/forum/Forum10/HTML/001899.html Drew |
If theres anything I can do to help, just email me.
Greg ------------------ 69 convertible LT1 4L60E |
Greg, can i use an aftermarket wiring harness just to run the motor to the computer? Do you know anything about the lt4 hot cam kit. Would I get more horses with an lt4 intake as well? Thanks
(it's LT1 not lt-1 LOL)
the lt4 intake is for lt4 heads which feature a slightly different intake port shape gmpp has a carb intake if that matters aftermarket wiring kits are simpler corvette accessory bracket fits older cars better 94 and newer use a computer controlled auto trans 92 and 93 are speed density, 94-97 are mass air flow as well as sequential firing instead of batch firing 96+ are odb2 (4 O2 sensors) and are far more sensitive to throwing codes d shaped exhaust ports - plenty of header choices, most of which I think would work in older car w/ custom y-pipe or true duals the iron b-body heads actually flow better 95+ use a longer dowel off the cam to drive the opti I'm sure I'll think of more little things to toss out later plenty of lt1 swaps going on, great motor, with the unfortunate drawback of a unique block ------------------ '68 Camaro (Baby) - 333, 200-4R, custom interior and paint, 12bolt going in soon '94 Z28 (Pepe) - stock heads/cam and 3.23 gears - 12.44 @ 106+ 1.68 sixty, all motor (Jan '03 GM High Tech Peformance cover car) a few other toys some pics on the page: http://fastz28.cz28.com [This message has been edited by fast (edited 01-16-2003).] |
FirstgenLT1 here is a link to my webpage documenting build up of a 1969 Camaro convertible with and massively massaged 94 LT1. I will also include a couple of links from discussions on camaros.net and pro-touring.com that relate to this car. Good luck with your project and post some pics.
bob spears http://homepage.mac.com/bspears/Menu10.html http://www.camaros.net/forum/Forum2/HTML/004873.html http://pub59.ezboard.com/fprotouring...cID=1039.topic http://pub59.ezboard.com/fprotouring...cID=1035.topic ------------------ 69mscle |
