Tech 2003 General Tech Area from 2003
Replies ONLY, no new topics.
Old Jan 17th, 03, 04:30 AM
cottonpicker14 cottonpicker14 is offline
Default
THe former owner installed a Brute Strength posi unit and 4.10 gears.
From what I understand, its a Carrier 4 unit and is suppose to use only gear ratios of 4.10 to 6.10.
I would like to install something higher than 4.10's, like 3.73 or 3.55's
Does anyone know if there is way to install either of these ratios in a Carrier 4 unit ?
Old Jan 17th, 03, 10:00 AM
TJS69 TJS69 is online now
Tom
Default
You can install 3.73's made for a 4-series carrier. There is no higher (numerically lower) gear ratio available. Ironicaly this is a thin gear higher priced than a comparable thick gear.
69 Camaro Z28 "clone" - 327 AT
"461" camel back heads,
edelbrock , hooker, ultradyne cam, stewart,
TRW etc.
Vintage Air (not yet installed)
700R4 TPI transmission
Old Jan 17th, 03, 03:42 PM
ZZ-28 ZZ-28 is offline
Default
Cottonpicker, are you from Robstown by any chance? Class of '65.
