| Team Camaro Tech Current Topic: who knows how to size the head of a bolt when its measured in thread size | ||
| Tech 2003 General Tech Area from 2003 Replies ONLY, no new topics. |
I am looking at some stainless bolts but they come sized in thread size, not bolt head size.
I need to know, as an example, if the thread size is 5/16 what would the size of the hex head bolt be |
All bolts are sized by thread diameter unless they are a special sholdered bolt or something like that.
All bolts are measured by the thread diameter, not the hex head size. Thread sizes are usually stated like this: 5/16-18 x 1. This bolt would have a 5/16" thread diameter, it has 18 threads per inch (this is called thread pitch), and the threaded part is 1" long.
You should be able to get a bolt sizing tool (it is a flat piece of plastic with several different sized holes in it) from Lowes or any decent hardware store. While you are at it, you will probably need a thread pitch gauge. It looks like a small set of feeler gauges, except the gauges look like small saw blades. ------------------ 69 Camaro 400 Small Block Trick Flow Heads Comp 282S solid cam Performer RPM intake 750 CFM Holley and a Muncie four speed Pics of My Car |
Though thread sizes are spec'ed by their thread diameter, pitch, and grip length, here are some general guidelines for head size vs thread diameter:
1/4" diameter = 7/16" head 5/16" = 1/2" 3/8" = 9/16" 7/16" = 5/8" 1/2" = 3/4" These are generally accepted sizes for general machinery and most carry over to automotive sizes. However, the thread size is what's important. As stated above, a thread gauge is your best bet. Also, when buying the bolt they will be spec'ed like 3/8"-16x2. 3/8" = thread diameter 16 = thread pitch, or the number of threads per inch. 2 = grip length, or the distance from the end of the thread to the bottom of the bolt head. If you are dealing a critical component such as an A-arm, caliper, ect. where fastener failure could mean your life then please educate yourself about fastener grading systems. Grade 8 is generally accepted for critical components, but even here there is a lot of room for error. ------------------ The Red Beast http://www.geocities.com/casanoc |
On a side note, a high bolt grade is very strong length wise but side to side stress is weak. Due to being so hard its brittle.
Rockwell scale<sp> ------------------ My '68 Camaro Doug G. 68 Camaro 406 ci. 13.5@102 W/ 2.73POSI. [This message has been edited by DOUG G (edited 01-21-2003).] |
You don't want a stainless steel head bolt.
Regular bolts will not work for head bolts. The stretch and spring tension of the head bolt is critical to it holding the head. Regular cylinder head bolts are steel and the shank is thinner than the threaded area to allow the bolts to stretch and hold tension on the cylinder head. They really funcition like super stiff hold down springs. David ------------------ Check my web page for First Gen Camaro suspension info: David's Motorsports page First Gen Suspension Page 67 RS 327 original owner. 69 Camaro Vintage Racer, 65 Lola T-70 Chev SB Can-Am Vintage Racer |
<BLOCKQUOTE>quote:</font><HR>Originally posted by DOUG G:
On a side note, a high bolt grade is very strong length wise but side to side stress is weak. Due to being so hard its brittle. <HR></BLOCKQUOTE> Not always true according to the maximum shear stress theory. Check with the bolt manufacturer for accurate specifications on tensile stress and shear stress. ------------------ [This message has been edited by 72SSAbody (edited 01-21-2003).] |
Unless you're buying genuine ARP or SPS stainless alloy bolts, don't even THINK about using "stainless" bolts for any kind of a stressed application (suspension, steering, brakes, engine, etc.); 90% of the "pretty" stainless bolts on the market (other than ARP, SPS, or Brooks) are SAE Grade 2, which is about the same as the lag bolts farmers use on gate hinges. After 37 years of dealing with highly-stressed premium automotive fasteners every day, I see this "pretty" stuff at car shows all the time and it gives me the willies.
------------------ JohnZ CRG '69 Z28 Fathom Green |
