Tech 2003 General Tech Area from 2003
Replies ONLY, no new topics.
Old Jan 20th, 03, 03:22 PM
linda30 linda30 is offline
Default
Hello I have a 89 camaro rs! I had the car for one day it was fine the day I brought it home but went to get in the day after and now nada! I replaced the starter but that isnt it! If you have any Ideas please Let me know I will be grateful Thanks
Old Jan 20th, 03, 03:58 PM
KevinW KevinW is offline
Kevin
Default
Linda, please give us some more info. do the lights come on? starter spins or not? do you hear clicks from the starter? engine spins but not firing? which? Then we can help.
Kevin
Old Jan 20th, 03, 05:00 PM
Default
The lights and radio come on! I got a new starter and there is a new battery! It does nothing like there is no battery in it!
Old Jan 20th, 03, 05:54 PM
ZZ430DropTop67RS's Avatar
ZZ430DropTop67RS ZZ430DropTop67RS is offline
Don
Default
linda30,
If everything works, but engine won't crank, you could have a "Pass Key" problem.
That pellet on your key. Could be the wires from the ignition lock cylinder are broken...very common. They are very small (2).
Not really hard to change (the steering wheel must come off).
Don~ ZZ430DropTop
~~~~and~~~~
70 RS
[This message has been edited by ZZ430DropTop67RS (edited 01-20-2003).]
Old Jan 20th, 03, 07:38 PM
sixtsevnssrs sixtsevnssrs is offline
Tim
Default
Linda,
Check your connections at the battary and the other end that should attache to the alternator bracket. What year is it? There is also a fusable link that comes off the starter to your ignition on some 70's ~ 80's vehicles. Looks like a regular wire, if there is any swelling that you can feel in the casing of the wire it should be replaced.
Have your battary checked, it might be new but just because its new doesnt mean that its good. Also if your voltage is low on the battary your lights will come on but not have enough juice to turn your motor over. If its less than 12.5 volts have it charged. If its less than 12 but still checks out good from the test, your alternator is suspect have it checked.
Usually its nothing more than a bad connection either at the battary, the starter or you battery ground to the motor.
Just a few ideas.
Tim
67 ss/rs,
My slice of the web!!
Old Jan 20th, 03, 08:31 PM
Default
Thanks I will check out anything Like I said I had it for one day SO I am excited to get it going! I have heard about the fuseable link a lot over the past few days. It is a 89
Old Jan 21st, 03, 01:27 PM
gr868 gr868 is offline
Tech Team
Default
Check your neutral safety switch. If it's bad, car won't crank.
GR868
68 SS
Old Jan 21st, 03, 01:38 PM
Z28 Mark @home
Guest
Posts: n/a
Default
Check the cables…. My 88 did the same thing. Turned out to be the NEG. cable. What I did to prove it was to use a pair of jumper cables and went from GND at the battery to a GOOD GND on the motor. Car fired right up.
Mark (A.K.A. Z28 Mark)
