Tech 2003 General Tech Area from 2003
Replies ONLY, no new topics.
Old Jan 24th, 03, 08:52 AM
ffcagle34 ffcagle34 is offline
Default
I am changing from a 68 shifter that uses a cable to a 67 shifter that uses a lever or rod. Does anyone know of a conversion kit available or what hardware I would need to do this the right way. My manuals are not real clear on the hardware needed. I will need to buy the connecting rods and linkage since I do not have them. Thanks
Old Jan 25th, 03, 01:07 PM
1 2RUN 1 2RUN is offline
Default
Classic Industries sells conversion rods originally designed to switch from powerglide to TH350 or 400. It should fix you right up. Give them a call and tell them what you're doing. They'll be glad to help. 800-854-1280
'69 RS Camaro
355 5-speed 4.11
Old Feb 5th, 03, 12:32 PM
Default
One of the techs at Classic Industries told me that because of the difference between the 67 and 68 there is no way to use a 67 shifter that uses a rod in place of a 68 shifter that uses a cable. Anyone agree or disagree.
I would really like to use this 67 shifter because I have the console to go with it. Thanks
Old Feb 5th, 03, 03:47 PM
Ocala67RS Ocala67RS is offline
Team Member
Jerry Cox
Default
I may have a extra shifter, but I have converted it to be used with a 700R4. Send me a email if you are interested. Jerry
67 Marina Blue RS
327 365HP, 700R4
Ocala FL
