Old Feb 27th, 03, 03:29 PM
frankk frankk is offline
Post
Need to know about the visual and external differances between Muncies and Saginaw trannys.I'm going to have a look at one thats for sale, and the fellow said he thinks it may be a Saginaw because it has a cast steel case. The only numbers he had were 338835, A24 and GM9 Thanks for any help, Frank
Old Feb 28th, 03, 01:47 AM
Everett#2390's Avatar
Drive a '68!
Cool
You are corect, Muncie is an alum case and tailshaft extension, as well as having the the reverse shift mechanism and idler in the tailshaft housing.
Saginaw is a cast iron case with cast iron tail housing, as well as having all three shifters in/on the side cover of the main case.
Hint: select a gear and turn the input shaft by hand to see if the speedo pinion turns. [img]graemlins/thumbsup.gif[/img]
Give a man a rescue dog for the health of his soul.
My 68 Camaro http://www.flickr.com/photos/everettwn68
Old Mar 1st, 03, 12:42 AM
fujimook fujimook is offline
Tech Team
Post
Easy visual difference between muncie & sag 4 speed, Sag has all shifter shafts in side cover, muncie has 2 in side cover and 1 in extension (rear housing). Ratios for sags can be found here:
http://fteufert1.home.att.net/trans/saginaw.htm
Ratios for muncies here:
http://www.peachstatechevelles.com/muncieid.html
70 Nova, balanced 327+ .030, TRW small dome, AFR 195's, Comp Cams xs268s, Performer RPM, Holley Spdbore dp, self-made cowl cold air and HEI, headers,4 speed, Powertrax limited slip
http://rides.webshots.com/album/29514738sryMYECvOx
Old Mar 1st, 03, 02:04 AM
ckaram's Avatar
ckaram ckaram is offline
Chris
Angry
Go to Hurst's website, click on Online Catalogs, then Transmission ID.
You'll be able to look at the visual differences of the tranny's.
http://www.mrgasket.com/hurstmain.html
68 Camaro ragtop, original 327, CCHE268, Dart Iron Eagle heads, Holley 650, Doug Thorleys w/Magnaflows & 2.5" exhaust, Muncie M20, 3.08 posi, 4-wheel discs
2010 Camaro 2LT RS, Red Jewell Tintcoat, M6, White hockeys, Beige leather, Sunroof
