whine coming from transmission - Team Camaro Tech
Old Feb 18th, 04, 07:30 AM
pab007 pab007 is offline
Post
My friend has a 93 Z28 with a 6spd manual transmission. We were racing the other day, and I guess the high revs shook something loose. Anyhow, there is a high-pitched whine coming from the tranny. It increases in pitch with rpms, and disappears when the clutch is pressed. Also, it appears to vanish, or at least be harder to hear in 4th, 5th, and 6th gears. Any ideas on what might be causing this?
Thanks,
Jacob
68 Camaro<br />383<br />T56 6spd<br />Eaton posi w/ 3.73's
Old Feb 19th, 04, 02:19 PM
68sixspeed 68sixspeed is offline
Dan
Post
Doesn't sounds pretty-- could be the input shaft bearing or something on that end of the tranny... Time for the fun job of dropping the tranny. Also check the pilot bearing while it's out- it could get wiped out if the input bearing goes.
-Dan
