M20 - Team Camaro Tech
Old Mar 24th, 03, 03:57 AM
countrycamaro countrycamaro is offline
Question
Is there any difference between a M20 used on a 69 Firebird and a M20 used on a 68 Camaro. Can they interchange without any problems.
David
Old Mar 24th, 03, 06:25 AM
tloleson tloleson is offline
Tech Team
Post
Same trans.
Old Mar 24th, 03, 02:00 PM
crashent crashent is offline
Post
countrycamaro, A 1968 and older muncie uses nuts to attach shift levers on the studs on the shift cams. 1969 and newer uses bolt to attach shift levers to shift cams. They both should have passenger side speedo cables for F-body use...Hope this helps...Crash
Old Mar 25th, 03, 03:52 AM
69X11SS 69X11SS is offline
Post
The internals are the same for both trans. The side covers differ in the method of shifter lever atttachment. Everything else is the same.
There is a fine line between hobby and obsession!
69 SS, 350, 4 Speed
69 350/350 4 Speed Corvette Convertible
Our Cars Click on my Cardomain user name to view both cars.
Old Mar 25th, 03, 04:27 AM
ckaram's Avatar
ckaram ckaram is offline
Chris
Post
Are the input shafts the same? I thought they were different.
Check my rides:
1968 Camaro Convertible 327, 4-speed http://www.camaro5.com/forums/pictur...pictureid=1573
2011 Camaro SS/RS LS3 http://www.camaro5.com/forums/pictur...ictureid=53642
Old Mar 26th, 03, 04:54 AM
Post
Thanks for the information. I am in the process of switching to a 4 speed from an auto and have located a m20 from a 69 firebird. The question about the different input shaft is now a concern if it is true.
Anyone able to answer that one?
David
Old Mar 26th, 03, 07:22 AM
Cameron Cameron is offline
Post
There are two input shafts that are available with a Muncie four speed. One is a 10 (course) spline and the other is a 26 (fine) spline. If this tranny came out of a 69 Firebird, I believe that it should be a 10 spline shaft, but that could have been changed to a 26 spline over the last 30 years. It is easy to tell the difference. Either input shaft will work, as long as you buy the appropriate clutch disc. You would buy a 10 spline disc for a 10 spline input, etc.
49 Chevy 3100 Project
Acro Sport II Biplane
69 Camaro
400 Small Block
AutoGear M22 4 Speed
Old Mar 26th, 03, 08:24 AM
Post
Thanks Cameron!
It is a 10 spline.
Thanks to all!
David
